Boosted5speed
About Boosted5speed
- Birthday 11/01/1979
Location
Austin
Vehicles
1995 Legacy LSi
Recent Profile Visitors
Boosted5speed's Achievements
Member (2/11)
10
Will any 95-97 subaru TZ102Z series transmission work in a 95 legacy LSi? I've asked a similar question before, but the difference here is I have a specific transmission im interested in. I sourced a TZ102ZA5AA out of a 97 impreza 2.2L coupe that has fairly low mileage for cheap, and im trying to make sure it will work before I bite. My legacy has a TZ102ZAAAA transmission in it, and from what I can tell , both cars have the same final drive ratio (4.11). Will the Impreza transmission work with the legacy TCU? Is there anything else I should be aware of before going w/ the Impreza transmission? Any information is appreciated, tired of the darn thing sitting in the garage.
I saw the dallas one, and was going to call and see what the code on the transmission was thank you for looking, appreciate the help - it such a pain to find subaru parts down here most of the time. =[ scratch that - the motor/tranny combo in dallas was out of a FWD legacy - for some reason I forgot they even made those.
Yea the transmission I found from the impreza was the only one close by that was a reasonable price, which is why I was asking about interchange . All the legacy transmissions out of 2.2 cars were quite expensive =[ Wow im being silly today - that transmission chart is for manual transmissions lol. Anybody happen to have something similar for the auto's? Code for the tranny is a TZ102ZAAAA-C
Had another thought - will the auto's out of 2.2 impreza awd's work in my legacy, or are they different. Is there a faq or list of swappable transmissions for the legacy? looking at http://www.northursalia.com/techdocs/trannychart/trannychart.pdf - everything looks pretty similar except the impreza tranny has a slightly shorter 4th gear ratio, which wouldn't bother me all that much, should everything else just bolt up or would it need a different tcu, and if so can an impreza tcu even be used in a legacy. Mainly just asking because I found a transmission out of a 95 impreza 2.2 liter awd for 300 bucks.
Well, appreciate your help nipper - guess I need to start looking for a local transmission shop - though I wonder if it might just be easier to find a used working tranny cheap and swap it in, I can probably handle the R&R pretty easily. Im kicking myself for not buying the 98 OBW tranny I saw on craigslist for 275.00 a couple weeks ago :-\ Bytw - I'm in Austin, Tx if anybody happens to be in the area and can recommend someone to take it to.
Let me try describing the issues a little better then First off, the car has no warning lights active - No CEL codes, trans temp light is not on, but does illuminate as normal on startup. Putting the car into reverse, engagement is very sudden - as soon as you put it into reverse it "jumps" into gear, doesnt take a second or two to build line pressure like normal. Putting the car into drive puts the vehicle into 3rd gear - wont accelerate to 50mph, no overdrive, no downshifting - engine feels like its bogging if you floor it. I do not "know" that the car is in limp home mode, but all the symptoms feel exactly like the ones described for being in limp/failsafe. Manually downshifting through gears changes nothing, feels exactly the same. Manually putting the shift lever into 1st gear causes the car to not move - when you step on the gas, the car feels like it is fighting against a transbrake, or heavily applied brakes (aka trying to brake torque a rwd/fwd car to get the wheels to spin). Not describing normal engine braking when first is manually selected, more like its fighting against the brakes to even move (but the brakes are not engaged) No codes showing, everything looks plugged in, fluid looks good, speedo works, engine feels normal, all the axles are solid, going to fwd only mode changes nothing in the feel. Dont notice any binding with sharp turns either. =\ I'm just kind of lost, and wish I had a 5speed at this point It sounds like the description of what happens when one of the shift solenoids fail, yet its not tossing any codes which I thought it would do.
~159,000ish miles, fluid/filter changed at the 135kish range - don't remember off the top of my head. Tranny fluid is clean and fairly red still, no burnt smell, no metal flakes in the fluid. And everything appears to still be plugged in fairly solidly . And yes, the speedometer works fine. Would limp home mode make the transmission feel like it has a transbrake or your brake torquing the car when you manually put it into first? And THANK YOU! all for the help - its amazing how helpful Subaru owners are compared to some others - I tried posting in a maxima forum asking about timing issues and it took days before I recieved anywhere near this amount of replies.
After using an obd-2 code reader, I have 0 sensor or transmission related faults at the moment, and no CEL =\. Going back outside to check the transmission wiring as suggested. thanks. Also, I saw that info in the 4eat pdf and was thinking that could be it also, only problem is finding a shop that can check it out/repair it for a reasonable cost. Wouldn't something like that also signal a transmission temp sensor warning as well?
Hey everyone, I have a 95 LSi auto with a transmission issue that apparently appeared overnight. About 4 months ago, the car was running/driving perfectly. I parked the car for the evening, and when I started it up the next day and attempted to drive off it appeared to be stuck in limp mode - the car only has third gear available. Reverse works fine, but engages rapidly when you first move it in (no ~1.5second delay like normal, just a ridiculously fast engagement). Manually selecting 2nd feels the same as third, manually selecting first gear and the car goes doesnt want to move - stepping on the gas feels like the brakes are on, with the car still attempting to move. The car does have a check engine light on, I haven't had the opportunity to grab an OBD-II scanner and check it out, but the check engine light was on for other emissions related issues before this occurred. I also didn't think limp home mode would make first gear feel like that. Can the limp home mode disable first gear to where it feels like that? If anybody has any suggestions to figure what it might be that would be awesome - the transmission shops around here want more than it would cost to buy a used transmission just to diagnose the problem, and all seem bent on selling rebuilds.
Hi guys, i was just wondering, my 90 leg fwd 5speed car has the loose crank pully/messed up crank key, i was going to replace my pulley (since the keyslot is worn on it) and i found a really good deal on an underdrive pulley for the ej22. Im just trying to decide if there are any bad points to using an underdrive pulley on these cars. Im going to try and repair the keyslot in the crank itself with some jbweld and the key, and hope it holds long enough for me to arrange the cash and source an EJ22t from a 91-94 turbo. Mainly im just asking if there are any negatives to going with an aftermarket underdrive pulley, as i can get a new one for ~ 20.00 more than a junkyard pulley. Thanks everybody.
