Everything posted by Ricearu
To the O.P., rent a block test kit (tests coolant for combustion gasses) from autozone/advance. all you really have to buy is the strips. then return the kit and they give you your money back. takes a few minutes and isn't hard.
Headgaskets. and by the way, overheating is technically over half way. I blew a headgasket on my 92k mile ea82 by just pegging the "red". A wire broke off my fan relay and caused me to overheat in traffic, just for a moment. same symptoms. overheat on highway etc etc. here's a hint also, stop driving it now before you trash the oil, once the oil overheats and breaks down, rod bearings go next.
rapid solenoid click indicates low battery, poor connection or bad solenoid (on starter). start there. even though the battery shows the voltage, it can be toast, providing too low of amperage to crank the engine. try jumping it and see if that starts it. otherwise hit the starter solenoid with something. like a jack handle while cranking.
Whats broke on your subaru lately.
Ricearu replied to The Dude Abides's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Put it in gear, set the ebrake, and let the clutch out and look to see what axle nut is spinning. That will be the stripped hub. The rear output is driven off of the front diff. Nearly impossibe to break and drive home in 4hi. I say stripped hub from improper torque also. Seen it more times than you count and people assume. Ithe worst. Maybe broken axle. I had one strip on me. -
Seafoam, any thoughts?
Ricearu replied to tractor pole's topic in Old Gen.: 80's GL/DL/XT/Loyales...
make sure its a vacuum line at the throttle body, otherwise you will only seafoam 2 cylinders -
NOOOOOOOOO!!!!!! Worst plugs ever. you should know that twitch.... They widen the gap considerably as they wear, the electrode recedes rather rapidly into the insulator. They just don't hold up. *this post brought to you by bosch platinum haters of america* also, btw, love the wagon and good luck with the job!
Like a million bucks. I will try to get a vid tomorrow. its really hot. kinda gurgly on decel and no resonance (quack sound) like you would expect from a glass pack. also, I went to awesome's ALL you can carry for $35 sale. my back hurts but I got a rear disk swap, washer resivior, center console, shifter trim, etc and made a shift boot from a pair of old work pants
http://www.youtube.com/watch?v=SfWX7T99kPw Is this what it does? check all wiring first and clean the maf
Hey I feel your pain (i converted electric) To those who are having this issue, I had the same problem after installing my "new" engine last year. It died on the highway. It would run for about 20 miles then decide to peter out. It took 2 weeks of this, after jiggling junk while it was chug chug "idling" I found it ran good if I messed with the main engine wire harness by the left side of the engine (left from sitting in driver seat). when I got home, I unplugged it, sprayed it down with contact cleaner, plugged and unplugged it and hosed it with contact cleaner again. 18k later no more wiring or dying issues. only a starting to leak headgasket...
Running rich and need a fix
Ricearu replied to dave+Sub=trouble's topic in Old Gen.: 80's GL/DL/XT/Loyales...
http://cgi.ebay.com/ebaymotors/Subaru-1985-1987-1-8L-OHC-EA82-Weber-Carb-Conversion-_W0QQcmdZViewItemQQfitsZMakeQ3aSubaruQQhashZitem4cf7279fbfQQitemZ330564083647QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
