Ricearu
Everything posted by Ricearu
  1. thanks. i did some backyard diagnostics and found that when I unplug the maf sensor, the car no longer bucks and surges like a madman. It runs better than it has in a LONG time just off the base map. I do believe I need a new maf if anyone has one!
  2. I bought THIS! The GL is uuber pissed. It literally backfired through the filter. And it is running slobbering rich and pissed off. I just spent $225 on a full new exhaust for the gl complete with "long tube" custom header to 2in1out mangnaflow high flow cat, and coolant flush and much more. STILL, It refuses to pull hills and such... DOES ANYONE HAVE A SPFI SPARE INJECTOR I COULD HAVE, I NEED TO SEND 1 TO OSIDETIGER.COM AND I COULD SEND BACK MINE to you once I have it installed.. I think mine is dirty or sticky and just pissin the fuel into my engine instead of atomizing it. I cannot explain why I get 20mpg or less over the last few months. new 02 sensor, stock size-ish tires, and all highway driving at 60-65mph. It also slowly overheats if I exceed 55mph anyways, the GL will be parked for the time being as I bought me a new daily driver. its got some slight body damage and needs a pass front fender but she is AWD 5 SPEED with 181k and i paid $650 cash with clear title! :banana:
  3. mine work fine and are from a isuzu rodeo 16" steel six spokes
  4. your one filter probably won't cut it. it needs light vacuum.
  5. my advice (this is from when I had my standard hatch (std). I did the same thing and turns out I had a stuck ring. Remove all the spark plugs, Dribble about 2oz of MARVEL MYSTERY OIL into the spark plug hole just before top dead center (one at a time) reinstall the plug, then SLOWLY apply pressure on the crank bolt with a breaker bar to force the MMO past said stuck rings (DON'T USE THE STARTER OR YOU WILL BEND A ROD) Take your time and do it ONE cylinder at a time. as you do the rest, take the "done" plugs out and leave rags over the holes so any excess MMO can escape. when you have done all 4, clear the area, cover the plug holes with rags and spin the engine with the starter to clear out any remaining mmo. dump the rest of the MMO into the oil, reinstall plugs, and fire it up. give it 5 minutes or so to work with the engine running, then change the oil. I have had this work before and it's worth a shot to see if it can fix it for you. also, if you have alot of miles on your engine, you may want to run a thicker oil. I run 15w40 shell rotella in both my subaru's because they all have MILES on it.
  6. I have daily experiences with chinese internal combustion engines! I run a chinese atv/scooter parts department, and not some two bit dealer, I work for the manufacturer owned importer! Miles if you need parts, let me know. I already have a cheater 50cc scoot, which is really a 63cc from the factory, and all I did to it was an 88 main jet and 6.5g dr.pulley sliders and I have had her to 53mph on flat land. that was a really long straight normally she will do about 47.
  7. she is a 150cc and so far I have had her to 55mph on my street! shouldn't be long before she is insured and on the road. I cant handle that much chrome in one package... so I partially murdered it out
  8. Those look incredible, only one problem, you need to repaint or reclear the rest of the car to match. I like your car, and I like the paint. Im not hating, just that they look.... too good.
  9. just buy a used (low mile ish) ej25d do the gaskets, with subaru MLM gaskets, and buy a conversion and stuff that into the car. its 165hp and really perky engine. I love the one in my forester, just has piston slap till it warms up. Last week I made a run to home depot, then to work, 140miles with a 16ft car hauler and it didn't complain.
  10. check for other rust. they did a sorry job sealing the ends of that tube from the factory. just start hitting subframes underneath with a hammer. if everything is solid, then just replace what's done.
  11. i want to put ej seats in my wagon, just for the simple fact that my driver seat looks like it went sunbathing in front of a firing squad, then a knife wielding slasher got to it, then an elephant stamped on it.
  12. even in 2wd the rear differential spins the driveshaft. ujoints can cause this. Grab the yoke of the diff and check for play. if no play, then you are ok to replace the driveshaft.
  13. smells a little fishy to me... http://www.rockauto.com starting at $5 on closeout, $20 normally. shipping usually is cheap as dirt also. maybe $10.
  14. also what most people don't know is that when using sealant, put it on in a thin layer(1/16" or so), snug the bolts just until the pooky starts to squish out then let it sit for 30 minutes or more to firm up, THEN torque the bolts to spec. this allows the pooky to act like more of a gasket instead of a glue.
  15. thats good to do. I have people want me to do timing belts for them, and I refuse if they don't replace the idlers, and water pump(if tb driven) and explain why. one of my friend's would not replace the idlers on his 1.8 impreza, one locked up, pulled out the threads from the case and then stripped the new belt. so I charged him for idlers, the whole job again, helicoil in the engine case, new belt and labor (cheap for friend)
  16. It truely is luck of the draw. I bought 2 new cardones from oreilly's for my wagon, one knocks under acceleration and light turning only, the other works great. I have been too lazy to go yank it to have it warranteed. my experience with autozone dura-crap axles is not to trust them further than you can throw them...
  17. good deal on the rear discs. I love mine. saved me from rump roast-ending a tahoe that cut me off when HE had the yield and jumped into my lane. didn't even lock wheels up. it just went from 50-0 in an instant.
  18. I have a chinese moped, cost me like 800 new. then i bought a house in the boonies where the County roads are all 55mph... my moped has 56 miles on it and with variator sliders, it runs 45mph :banana: nowadays, i just ride it to the mailbox it's for sale. I need a 150cc to ride to town
  19. check to see if your tires are the same size. also it can be affected if the fronts are bald and the backs are still good then the tire sizes are effectively different, even though they all say the same size on the side
  20. mine never rumble. ever. i would think to check the u-joints at the carrier bearing first
  21. tstat is on the passenger side. get it from the dealer. the aftermarket ones are JUNK.
