Everything posted by Ricearu
86 EA82 Wagon, no start. Plz Help.
Ricearu replied to Ricearu's topic in Old Gen.: 80's GL/DL/XT/Loyales...
sorry i forgot to mention, It is carb'd. Where is the rev sensor on the carb'd cars. -
sounds like something is bent
I put an engine in a 86 Wagon for a friend, now everything is gravy, but the fuel pump won't kick on. The book says something about a revolution sensor and I can't find what its talking about... The Fuel pump is NOT getting power. I Have checked the fuse. It is good. It will "run" on ether(starting fluid), so I know the dizzy is "good" The fuel gauge is pegged at empty, even though I dumped 4 gallons in it... Not sure if this is related though Will I need to rewire hot from fuel pump fuse, or does anyone have a solution for this?
Yeah I busted a lens about 2 weeks ago.
Help! :: GL-10 Wagon Electrical Gremlins
Ricearu replied to slminneman's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Don't want to freeze my arse off again.
Ricearu replied to jonas's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Mine did the same thing, I had NO thermostat. Put one in it, and worked like a charm -
I think I am gonna weld/grind/paint over the old holes in my wheels so this can be avoided, I am also gonna chamfer the new holes to seat the lugs into. I would prefer no tire monkey touches my car anyways unless absolutely necessary. This will also benefit me if I were to get pulled over and the cop were to think I have 4 lugs missing from each wheel :lol:
I want them higher, but I digress
stalling/surging while cold
Ricearu replied to nathan.chase's topic in Old Gen.: 80's GL/DL/XT/Loyales...
start with the coolant temp sensor, if they short, they tell the computer something like -40 and if they open, they tell it like 250* or vice versa. If it is has a short or open in the sensor, it can lean the computer out, but while its cold, It should be enrichening the engine until its warmed up. I have experienced this with other cars in the past. I would get a Multimeter and check the OHM's to what the book says it should be when cold/hot. -
Yet ANOTHER problem! Clutch? Bearing or cable?
Ricearu replied to Fox's topic in Old Gen.: 80's GL/DL/XT/Loyales...
check and make sure your motor mounts are good and the bolts are still tight in the cross member, and check both bolts on the torque brace?(The bar under the spare from the engine to the firewall) Also check that the bushings aren't broken in it too, Mine has busted bushings and causes a pop when I take off quick (I am fixing to replace it with a NICE adjustable moped strut) I will post pics when I get it done. -
84 gl wagon backfires
Ricearu replied to coolskaterkid's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I used to drive a 74 VW Bug, UNBAFFLED Stinger (megaphone) Exhaust, Dual carbs ect. I would come down an off ramp, hit 2nd and you would think you were in a shootout! BBBRRRRRUUUHHHMMMMMMM.....POW....POW....POW..POW POW POW!!! BWWWAAAHAHAHAHAHAHAHAHA!!!! :lol::lol::lol::lol::lol: The two times cops pulled me over, I would just say "My baffle fell out the other day". Never was written a ticket -
duh me, I am post lagging. I was mixing post titles. Check your carb, you are running hella rich then. especially plugging new cats. -
Cool because I know a junkyard that has some mazda 6's for $50 w/tires
Unburnt fuel in the exhaust. Turbo cars run a little rich. Put a cat back on it. -
what about isuzu 6's and mazda 6's?
Justy Motor to Loyale D/R Transmission
Ricearu replied to Little Bandit's topic in Old Gen.: 80's GL/DL/XT/Loyales...
measure an ea81. You saw a ea82. plus, you won't like the power of the justy engine. NO torque. I used to have a Justy RS w/push button 4wd. SLOW. EA81 is in the 84 and before wagons/sedans -
'90 Loyale AWD Turbo Wagon
Ricearu replied to thecryoflove's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Also, if you can't get the axles back into the hubs all the way, take off the 4 hub bolts, then thread the castle nut onto the axle a few turns, and use 2 pry bars/screwdrivers to pry it through the wheel bearing. -
Resealing a DR 4MT: which flavor of RTV?
Ricearu replied to moped's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Ford Motor Company produces a BOSS silver sealant. Its not RTV, I think it is anaerobic. It is available from their parts department. That stuff is made from ground up ninja swords or something. I guess ford has to get at least ONE thing right. -
What are you using on the fronts? and how much does this lift the car over stock height? Also, do they HAVE to be w/o a/c springs?
