chopsubie
Everything posted by chopsubie
For full time rwd I would recommend removing the spider gears from the front dif and severely reducing its weight. Don't remove it because it plays a large part in lubricating the entire trans. Just reduce the rotating mass. Furthermore, remove the 4wd linkage and weld up the rear output clutch. Put two e brake handles in the center console and set them up to control only one side each. A little practice using the two handles to slow the spinning wheel you should be able to perfect the rwd burnout. But remember you only have 90hp to play with!
fuel sending unit resistance values
chopsubie replied to chopsubie's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Thanks for the response, however that is not what I found this morning with some inline resistors and potentiometer. 4ohms takes the needle right to the top of the printed full mark, and 69 ohms brought the needle just to the bottom of the empty marking. 0 resistance,aside from the very small amount in the conductors takes the gage needle to about 110%, 90 ohms sends the needle below the empty mark about -10%. A universal sending unit of 0-90 ohm Connected in series to a 4 ohm resistor would give me an accurate full level indication, and a conservative empty indication. I'm sure there are some deviations in the accuracy of the gage coils from car to car, and for cars with poor charging systems. I ran my test with a 13.5 vdc supply. Thanks again for the reply, it has been years since my last post. -
Can anyone tell me the stock resistance values for the fuel sending unit (in an 82 gl wagon). The fuel tank is gone, so I would like to fab a fuel cell and equip with a universal fuel sending unit to work with the factory fuel gage. Even if someone knows a close value i.e. 0-100 ohm? I'll hook a resistor and a rheostat up to the gage and dial it around until I find the empty and full values if I don't hear anything back. Thanks
Sorry guys, I did convert to coil, but recently sold the car....with all the old air misc. included.
I've had this xt6 with rotten air bags for awhile now. Want to get it back on the road. I have tried searching this forum with no luck. What model and year(s) Subaru front struts (coil spring) will fit the front, and same question for the rear shocks (coilover). Thanks in advance for any links or input. I'm dying to get this thing back on the road.
Any of you t-case guys find a source for straight driveline tubing? The OEM driveline on my 81-83 ea81 wagons is flared. I need to shorten the driveline and the only options I have is to buy new weld on yolks that use the more common Inch size tubing. (2.5" x .062 wall) If I could find some metric tubing for less than $100 bucks I could re-use the OEM weld yolks. Are you T-case guys using the sammy and Toyota drivelines with conversion U-joints? Thanks
thanks for all the input. Jacking it up did kick-start the process. Only to reveal the front bags are leaking. Looks like I am going to convert to coil spring. I hear the 95 and later impreza front struts are a good fit. I have access to a 96 legacy but I am told they are too long. I live in Alaska and could benefit from a little added ground clearance. Will they fit? I was hoping the longer legacy struts would help level it out ( I don't really care for the door stop look) so like milesfox, I have plenty of air suspension components to get rid of. The rear bags are good, compressor, etc. I'll give it away, you pay shipping.
Yes, the module. I have always heard them reffered to as bulbs. I would assume it would be under the driver dash. Perhaps the old one is Already removed.
I apologize, this is a lame question. I have searched and searched, car and internet. I cannot find the location of the blinker flash bulb
Just picked up an 88 xt6, drivetrain is solid, but the air springs wont pump up. If I jumper the compressor, it works. If I jumper the solenoid it opens. I assume it is a control sequence issue with the computer. Anyone know how to reset, or have any further diagnostics? Thanks
Has anyone here seen or tried a hot spark, or pertronix electric ignition, for there nippon or hitachi distributors on an EA81? http://www.hot-spark.com/1-Hitachi-Distributors.htm http://www.pertronix.com/catalogs/pdf/ptx/2010/ptx2010_ignition_conv.pdf
like I said before, I know the ea81 is not a high performance engine. I was just curious about others using the 38-38 along with other mods, and how well if at all it would perform. I too like the ej engines, however I have several ea81's & wanted to put one together to throw in an off road only buggy. I'm not expecting to rock out a 120hp ea81, just help it out a little bit. I do appreciate all the input and information you guys have here on the site.
why not reinvent the wheel? If we all thought this way there would be nothing better than plain stock. No aftermarket options etc.
Since I have the engine assembled with the stock cam, I just ordered a 32/36. I just want to know if anyone is trying new things with the ea81, the VW guys are not scared to get 3x the Hp from their 1600cc h-4's.
I see not many people are actively talking about their weber carb swaps, so I'll post this here because it is for a dedicated off road application. I recently built up an ea81, stock cam, stock bore, pistons, etc. I slightly ported the cylinder heads, and decked them ( about .007"). I plan on building some headers with 1-3/4" tube into one 2" with a decent high flow muffler. I will also add a 1-1/2" tube as a crossover as close to the cylinder head outlet as possible. All emissions will be removed, and the vacuum system will be reduced to a bare minimum.(alternator, brakes). I plan on using the hitachi 2bbl intake, but I may build a custom intake later(to separate the hot coolant and incoming air/fuel charge) I really wish I knew about delta camshafts back when I did this, and I will most likely be upgrading to one of their torque grinds some day. Anyways,Do any of you guys have a 38-38 weber on an ea81? If so are your cylinder heads, exhaust system, and cam stock? Is the 38/38 too big for the stock configuration? Is there enough room for adjustment on the 32-36 for both stock and higher performance set-up's? (I realize the ea81 is not a high performance engine, but is a reliable, dependable, and lightweight). Some of you might argue this is too much work and too much to ask from the ea81 design. I appreciate its simple design, just looking to get a couple extra pony's, and help it out on the bottom end some while maintaining or increasing it's dependability.
So now I just need to get some LH and RH 1" jam nuts, about 30' of 1.25" .120 DOM tubing, some long travel rear coilovers, and I can get the axle mounted to the car. Then I will need to modify the Isuzu driveline, build my 4.11 AWD D/R trans, and re-build the front half of my lift to incorporate a new front suspension using modified VW Superbeetle struts and new custom lower control arms, and more lift. I will also be building a sort of sub frame to connect the front lift to the rear mounting points on the body, for the 4 link to bolt to. The Superbeetle struts will give me an extra 2-4" of suspension travel in the front, IIRC. Also will be dropping in a Hi-Po EA81 that I am getting in trade for a Hatch (I hope ) -Bill "" build my 4.11 AWD D/R trans''' Will this be in a 4 speed or 5 speed D/R? I would like to know what model car(s) would have the 4.11 pinion shaft that you will need. I have several 4 speed d/r trans parts from different cars but all have 3.9 ratio. If there is a different trans out there that has a pinion shaft with a 4.11 that will work in the manual 4 or 5 speed D/R gearboxes, I would love to hear more!
This isn't the same car. I made a typo, it was in a XT turbo car. It had an aftermarket intake manifold with a holley carb, and the oil filter housing looked like an oil cooler.(plate exchanger. I'm going to try to talk to him today.
I just was checking out some old wrecked subarus. There was an Older RX, I wanted to see if the engine-turbo was still all there, and to my surprise there was a Mazda rotary under the hood. I believe It was an unmodified 5 speed push button 4X4 transmission (the original fuji starter was still in place). Has anyone here ever heard of such a thing? I would like to make and offer on this engine and couple it up to a D/R 5 speed If there aren't any specialty bell housing adapters necessary.
Where did you find that? Was it on a EA81 82 ej??
Older engine? are you running an EA81?
I have two different intake manifolds off of two different 82 gl wagons. One with a very short and low profile, the other has a longer and taller shape. I have a weber carb and I think it came with the lower profile manifold. My question is which of the two induction lengths produces the best bottom end torque, (EA81). Does anyone have any actual performance data that compares the EA81 with a Weber and a Hitachi carb?
I have alot of guts from some 83 gl wagons and one late 80's EA82 sedan with an Auto. My plan is to build a small utility 4x4 from these drivetrains. I built a pretty hot EA81 from the pieces, now I'm putting the gearbox together. All the EA81 cars I have had the 4sp d/r manual. The differential gears are 3.9 ratio. My question is how large of tire is anyone using with a similar setup, I would like to run 28" *10" and not have to use low range for screwin off on the beach (Verry soft sand and Mud). Is there another car with 4.11 gears I can transplant the ring and pinion? Is there a dual range transmission that came with 4.11 gears? any help would be appreciated. AC
