About vagen
- Birthday 07/11/1973
Location
Charlotte, NC
Interests
Autocross, Building race cars, collecting Watches
Occupation
fabricator
Vehicles
Leone RX AWD turbo Coupe
vagen's Achievements
Subaru Fanatic! (6/11)
2
Adding notes to Miata shock swap
vagen replied to vagen's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I managed to solve the problem by running energy suspension sway bar bushings on the bottom with the ES washer and OE bushings on the top with the stock washer. Note: remove the metal ring on the miata shock -
I am trying NB miata rear shocks on my RX and I will report that the NA rear shocks are shorter but NB will make a nice match for XT 2wd front struts with OE springs. I however am building a race car so Tokico illumina NA miata rear shocks will be going on these are 2 1/8" shorter than the NB shocks and have adjustable damping. I am still researching front shocks for the 4-lug suspension. I will try to add that info here as well.
this begs the question. what do ZX turbo injectors actually flow? they are touted as an upgrade but are they really?
turbo injectors are indeed 185cc this is why people often swap them for the larger 260cc turbo ZX injectors. I am running the stock injectors but I plan to run more than 4 of them when I go for much more power.
I have a sandwich adapter and run -10 lines to an 11x6x2 plate style cooler in front of the radiator on the passenger side. living in nascar land does have one or two advantages.
Lets see your before and after photos
vagen replied to Mr. Brat's topic in Old Gen.: 80's GL/DL/XT/Loyales...
before: And now: -
there are a few simple facts about turbo EA82s first they create a LOT of heat both in the coolant and more importantly the oil. I have added an oil cooler to mine along with the intercooler, this has significantly lowered my oil temps. look at your radiator find the thickest one you can and look for metal end tanks (usually on A/c equipped cars). The heads do crack on these cars but if you keep the deadly temperature extremes at bay it will take MUCH longer before they do. Finally 115 hp will feel great if you are used to 80 try to resist the urge to turn the boost up, without knowing exactly what your AFR is you could cause big problems really fast by getting boost happy. I hope this helps have fun BTW: look up WJW's posts on this engine he is one of the authorities on making big power with the EA82t
I have coil overs in the back with 450 lb/in springs on stock 4wd shocks. I need to upgrade all the springs about 150-200 lb/in. I will be swapping in a set of miata shocks for more travel (stockers are nearly bottomed out)
those are the style I'm looking at... Well the bolt on versions but same idea. here is why I'm looking at flares
