3
Everything posted by logic23
Cool if you are in columbus look me up. My shop is downtown. The Advanced clutches are the worst. I have had to take out two and replace them with the Exedy Kit. They sell the Exedy kit thru Car Quest. Its the same as the oem clutch. The Adavanced clutch used to be good. I hadn't bought one for a couple years but during that time the manufacturer started having the kits made in china. The problem with them is the springs in the clutch disk are junk and the metal in the disk is weak. I had to take one out a week later and one of the springs had almost ripped out of the disk....bad news. Just take it back they should give you a refund.
My 99 OBW with a 95 2.2 5 speed runs just over 3000 at 70. Are you aware of the reverse cut ring and pinion gears that you can have installed in a subaru 5 speed trans? Now you can run a complete subaru drivetrain in your VW...no adapter plates etc. I am going to tackle this in my 79 bay window( currently running a 78 Porsche 912s engine with type 4 fuel injection) this winter. Search reverse cut subaru gears. They are in Australia. As I remember the pics show a Manx buggy.
I've seen several 2.5 DOHC HG replacements fail (40-60K miles). 3 of them were dealer jobs. Don't mean to be a downer but the 2.5 DOHC engine has a lot of variables that can make it fail: headgaskets, plastic cams, idler pulleys and thousands of posts concerning head gaskets. Since no one has been able to explain the reason why this engine fails and then how to fix it I put this engine in the unreliable catagory.
ABS Light
logic23 replied to djmark7's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
It possible that the wires could have been damaged... To pull the codes there is a black pug under the dash to the right of the steering column with two black wires in the same harness . you insert one of the wires (doesn't matter which one) into one of the plugs ( do a search on the forum and you should be able to tell which one) then turn on the ignition. Voila the abs light will start flashing the codes. Nipper has a list of the codes. -
noisy lifter
logic23 replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Those lifters are pesky..i just had to replace one that had collapsed. Its easier to replace them than mess with the snake oils.Changing them out takes 20 min. Do it when it is cold. I did it hot. hot potato... -
head loosening
logic23 replied to Uberoo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
x2 on the breakerbar then gun drill to get them the rest of the way out. Also get a better quality 12pt 14 ive broken a couple cheap ones. -
I dont think it was a package thing. Every forester 98+ i've worked on has them. I've been adding them to the engines I rebuild for added longevity. The have aluminum thermostat housings with an added snout > hose runs to oil filter area where the cooler bolts where oil filter goes with a longer tube. the cooler has two snouts: one to the thermostat housing one to a snout that threads into a water jacket that has a 14mm allen plug. unthread plug then thread in snout and voila>>> oil cooler
So I have noticed that some 2.2 have adjustable lifters and some have hydraulic. Does anyone have a preference on which they think is better. When I messed with VWs the buses had hydraulic lifters which were nice and quiet but I used to run into problems with them freezing up and holding valves open or freezing up and making the worst valve tap ever. I have run into the freezing up and making loud noises with the 2.2 hydraulics Thanks, Craig
No they didn't and if you want to do it right its a bit tricky. The heated seats have a harness that hooks up on the passengers side foot area inside car. There is a relay that gets power from a block on the drivers side. The wiring is integrated into the vehicles wiring harness that runs inside the dash. You could take an outbacks wiring harness apart and cut out the wires and make a sub harness.
