Gender
Not Telling
Location
Nashville
Vehicles
I Love My Subaru
Bbob's Achievements
Member (2/11)
0
As usual, after buying a used 98 Legacy Outback and repairing head gaskets, I thought it would be nice to have the keyless entry working. I bought an ebay keyless clicker, then noticed the fuses had been pulled from the KE harness. Also the anti theft Ignition 2 pin plug was disconnected and bridged. The 4 pin plug next to it was also disconnected. Put fuses in KE harness which made the tiny dealer installed dash lamp flash and click an under radio area relay. Under dash reset button did nothing. Check Engine light is now FLASHING and rad. fan is cycling with clicking of many relays under hood and under radio. Cleared codes ; P0500, P1120, P1121, P1130, P1131, (don't know what these are) and both O2 Sensor Codes Nuts.... I'm probably lucky that it's still running.
I have 1995 Legacy L wagon 175,000 miles. Always loaded, it's driven very hard and treated rough. Never had struts replaced. Tires on orig. steel wheels & tires are 185 70 X 14. The alloy wheels to go on are 15in. diameter 6in. wide. Interchange book says they will fit the car. What is the largest tire that I can purchase without rubbing? Thanks in Advance!
I have used the Honda type Synthetic trans Fluid for the last 70K in my '95 Legacy Transmission . This year I lost my rear wheel drive. Saturday at 60mph on the interstate, "D" gear selection became neutral for 30 min. and then returned. "3" gear got me home. Been OK since. Futures?
