DanMac
About DanMac
- Birthday 08/09/1964
Location
Portland
Interests
Hunting,Jeep M715's & Subarus
Occupation
UPS Driver
Biography
Married with 2 boys,ages 9 & 6,And I'm a jack of all trades.
Vehicles
04 Turbo Baja,84 brat
DanMac's Achievements
Member (2/11)
0
Sealed wheel bearing question
DanMac replied to Greenley's topic in Old Gen.: 80's GL/DL/XT/Loyales...
You're a good sport GD. Have a great night. -
I STRONGLY disagree with that. Use an o-ring pick and carefully remove the covers, clean them thoroughly as you would with any other bearing before packing, then pack them as any other bearing, replace the covers and your bearing is set for a much longer life than the original. Done it many, many times and never had to replace one again after that. -
I tried something similar to this one time when I was a kid. . . It broke after a few hundred miles while I was making a left turn at an intersection. I had just been racing down the cliffs along the ocean on hwy 1 in SoCal before it broke too. Made me realize that steering is kinda important and not worth taking any chances. Trust me when I say this WILL break!
fuel economy
DanMac replied to Uberoo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
My 04 monster turbo baja gets 16 in town and 24 hwy. City milage would probably improve if I installed some better injectors instead of the Perrin modified ones I'm running now(stock injectors with the ends shaved down for more flow). My 01 2.5 rs averaged 24, 86 4x hatch got 26 which is the same as I'm getting with my 84 brat now. It's been along time but I seem to remember about 40 mpg with my 70 ff1 wagon with the 1100cc motor. -
Motorcyles, what are you riding?
DanMac replied to Slacker's topic in Non Soob Cars and Bikes Discussion
I've been riding an 05 Yamaha fjr1300 since new but have been looking at new Kawasaki Concourse 14's pretty hard. I've let the wife talk me out of buying it for now but don't know how much longer that will last. -
Pulled the cluster today (not to bad of a job at all) and found all bulbs to be good but bad connections where they twist in. Bent the contacts up a little, reinstalled, and wuttaya know, lights again! found this same problem with my 4wd and lo indicator lights as well when I thought for sure I had a bad switch on the trans. Glad I checked that while it was apart. The speedo cable was a cinch. Just have to remove the lower kick panel and reach in from under the dash.
Subaru must have been nuts!!!
DanMac replied to pheonix165's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I had a 1970 ff1 with the first ea motor (1100 cc) when I was 18 and ALWAYS drove it like I stole it and was making my get away. It had over 250,000 miles on it and aside from a little smoke, ran very well when I dumped it. I say run quality oil, change it often and drive it like you're mad at it! It'll take it and you're combustion chambers will be much cleaner for it. -
All sygnals work fine, just no indicators for either direction. Can't imagine both bulbs burning out and nothing else. I guess the cluster is gonna have to come out to figure it out.
I just puchased my first brat (an 84 with the ea81) and the turn signal indicators don't work. Anyone have any suggestions on where to start looking for the problem first? I am also wondering if this is a hydraulic or solid lifter motor as my book says both. DanMac
It's been showing up on craigslist for $2,000 obo on and off for awhile now.
Documented: The 1970 FF-1 Project car...
DanMac replied to Kostamojen's topic in Historic Subaru Forum: 50's thru 70's
Nice project! I had a 70 ff1 wagon with the 1100 in it that I bought for 100 bucks back in the early 80's. It took all the abuse an 18 year old kid could throw at it and still ran and drove pretty good with about 250,000 miles on it when I traded it off. -
I have been running meth in my baja with an avo500 turbo for some time now but it's only as a precaution so it was tuned with 30/70 meth/water (windshield washer solution) and you don't see a spike in hp on the dyno when it goes active at 12 pounds of boost. I don't think I'd run any more than that and only with the smallest jet supplied with the kit without tuning for it.
