4
Everything posted by obk25xt
How easy is it to bust into an EA82?
obk25xt replied to 92_rugby_subie's topic in Old Gen.: 80's GL/DL/XT/Loyales...
OK... maybe a lil' dose of reality here... You probly did it yourself.... I know I've done dumber ***************... But, mostly, who really wants to "joyride" in your car, i mean c'mon man, it's a 26 year old subaru sedan!? Not exactly on the list of targets for joyriders.... I'm willing to bet there's not a single person out there who drools over that car, 'cept for maybe you... Not trying to be a d!****** but seriously man.... Get over it... You did it, accept it...... -
b -
IDIDIT!! Seriously tho..... Ummm it's not like it would take much to steal one.. The ignition/door tumblers are frequently worn out out. And they're the same a datsun/nissan keys... My vote is... You left it that way..... -
JBweld fix
obk25xt replied to edrach's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
I did that too on an SVX I owned once. I was too broke to buy a replacement, and was commuting 140 mile a day. I went so far as to find the ends of the crack, and drill them to prevent the crack from growing. Then I filed/sanded and scuffed so the JB would have something to adhere to. It worked for a while, I don't remember how long exactly. But ya, things we do to get by.. Spencer -
^^^^^^ The 2nd pic is my old car! :cool: I have some used front struts from a 2000 outback, you can have them when you come up to get the transmissions.
I'm gonna lose the H2o-to-oil cooler and run a small filter to start with. I will ultimately relocate the filter and most likely plumb in an air-to-oil cooler.... I've been slackin on this project a lil bit, focusing on my home lately. I need to get back on the soob though, I NEED MY WAGON BACK!!!!!
Hi... Here I am.... Send me a PM!? I haven't heard from you either!? You back in town? Lemme know! Those trannies are just sitting up in my barn waiting for your attention! :-p
XT6 front sway bar hitting power steering line
obk25xt replied to subynut's topic in Old Gen.: 80's GL/DL/XT/Loyales...
This +1...... Never had any issues with mine other than the control arm touching as Numbchux has already noted..... -
Don't forget about width and offset. These 2 factors can cause rubbing issues regardless of overall height.....
How to fix back doors that don't open from inside.
obk25xt replied to 987687's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Ya sure, but now dating will never be the same....... -
T6 Rotella Oil Choice
5w30 -
Overall that thing looks to be in great shape! A little bit of rust repair in some places, looks pretty solid really tho. And it looks real straight too. Looking forward to seeing what you will produce out of this!
Sweet, looking forward to getting the manifold on this thing. Still have a few hurdles to cross. Nothing major just parts sourcing. I picked up a 98 2.5RS ECU yesterday to manage things..... Cams and rockers are installed. Oil and H2O pumps are installed. Need 1 more rocker bolt, musta lost one in GD's garage. Ran into a clearance issue with my oil cooler today though. Seems that the header I just bought will interfere with the oil cooler. If it doesn't interfere, it will be dangerously close. I won't know 100% until I'm installing it in the car, there's no exhaust gaskets installed in the pics, so that may just be enough to create some clearance. Even if it will all fit, it just seems pretty counter-productive. Sure the coolant will slightly cool the oil, but the header will be really hot too, nearly 20-40% of the surface of the oil filter/cooler will be at a very close proximity to the header..... I'm not opposed to massaging the header with a hammer to clearance if I have to. Guess if I HAVE to I can just lose the oil cooler, but I really don't want to..... Thoughts???
Today is my birthday.. So I went to pick n' pull! Got the hardware I needed to install the oil pump (STI), and water pump. And the bracket for the T-belt tensioner. Also picked up some of those rubber deals that go on the rear doors in front of the rear tires... From the GL10's.... Going outside to work on the engine right now......
The ONLY way a frankenmotor is a "power mod" in the world of the EJ powered car is.... When you put the 2.5 block in a place that was originally occupied by an EJ22. Slapping some EJ22 heads on you Outback, Forester, 2.5RS, Legacy GT, or any car that was born with an EJ25, is not a "cheap power mod" as you put it. READ!!! All your intrigue will become... Less intriguing... (Could take a while, but the knowledge is a good thing to attain) http://forums.nasioc.com/forums/showthread.php?t=631527&highlight=frankenmotor
Dragged her home today! Getting excited now it's here. Pics of the hole I get to stuff.....
I have 2 of them, both need repair.... 1 has bad front diff, the other has bad output shaft gears, take the tail section off the one with the bad diff, put it on the one with the bad tail section, and boom... You're set..... Make an offer via PM, they are located in east Clark county. I can also probly hook you up with a welded diff too.... You may have to do some assembly on your part, but the pricing will be pretty decent.....
Frankenmotor is built! Including a fresh hone, undersized and polished crank, NEW rings and bearings, NEW STI oil pump, NEW water pump T-belt etc..... NEW 2.5RS Exedy clutch, ACT Streetlite flywheel..... Transmission in the works...... More will be revealed.....
If you're using it in a lifted off road car you're pretty much wasting your time. The VLSD is designed to work with heat that is generated by friction at speed. Not likely created by motoring around in 1st gear in low-range. Most of them are worn out, or close to worn out anyhow, and are non-serviceable. A converted clutch type LSD would be better, still though you'll likely end up trashing it. The larger tire size acts as a larger fulcrum, the clutches wont "lock" if one tire is completely off the ground. Just weld it and be done with it.
Subwoofers for wagons question
obk25xt replied to SmashedGlass's topic in Old Gen.: 80's GL/DL/XT/Loyales...
8" Alpine rated to 1000 watts in bandpass box with 800 watt single channel pioneer amp......
