Hello everyone!
Newbie here from Canada, with a Japanese import 93 Impreza HX with air suspension. I've done searches on this forum and have learned a lot about the Subaru air suspension system. Thank you much!
Two question if I may ask.
Maybe I'm doing it right anyways, but in order to test the air discharge solenoid to see if it works, is it simply applying voltage through the blue and yellow wires? I've done this and there is no click sound or anything.
So asuuming I did this right and the solenoid is currently not working, is there a way to rebuild/repair the solenoid?
I know the factory repair manual says to replace the compressor assembly as a whole unit and not to repair inidividual parts, but I'd like to try. Has anyone done this or know if it is possible? I have an extra compressor assembly that does the same, no click form discharge solenoid so I would like to use this as a guinea pig.
And no, not quite ready to go to springs yet, though I do have a set of coilovers for the last resort!;-)
Thank you again!!
Ken
