Kostamojen
Everything posted by Kostamojen
  1. Son of a ***************! Just went looking through one of my part manuals on a whim... 806212030 Ball Bearing 12x32.5x10 And amazingly, I had a left over EA71 flywheel with that exact bearing on it... Fits perfect!!! It is indeed .5mm larger! Now I just need to find a new one...
  2. Son of a ***************! Just went looking through one of my part manuals on a whim... 806212030 Ball Bearing 12x32.5x10 And amazingly, I had a left over EA71 flywheel with that exact bearing on it... Fits perfect!!! It is indeed .5mm larger! Now I just need to find a new one...
  3. After seeing that list, I realized I still had a flywheel from my Impreza laying around. I tested it out, the 32mm is just a touch too small for some reason :-\ It just slides right through! Is there a "plus" sized bearing by any chance? I can't find anything listed at 33mm, and 33 might even be too large.
  4. Well its pretty close between 32 and 33, It could be 32.
  5. I'm looking for a pilot bearing with the dimensions of 33 OD, 12 ID for my FF-1 project. From what I've been reading, the 80's models used the bearings and not the internal crank "bushings" and I want one of the 80's style bearings for my EA63 flywheel. Does anyone have one handy to see what the dimensions are?
  6. Right now I'm looking into just getting some sort of flywheel based pilot bearing, size 33mm OD, 12mm ID. If anyone can find one, let me know...
  7. Thats the flywheel installed. The crank goes about 1/2 way into the flywheel. Do you think I could still put a pilot bearing on there? The clutch disc isn't even close to it, so there is like a half inch of room or more between the disc and the flywheel bolts.
  8. Wait a second, I don't think the pilot bearing will work... Look how the flywheel mounting location is "recessed" compared to the end of the crank. Just took these photos testing out the other bellhousing... If that pilot bearing idea doesn't work, I have to have a different flywheel (EA62) and modify the bellhousing to match...
  9. Just saw this thread: http://www.ultimatesubaru.org/forum/showthread.php?t=69663 Will an EA71 pilot bearing fit this 1400 flywheel???
  10. Wait, you mean something like this??? Did other model years have that kind of pilot bearing???
  11. You can somewhat see the pilot bearing in this photo: Here was the bellhousing issue I mentioned before: And the flywheel issues: Basically, if this is as serious of an issue as you guys say... I'm done.
  12. I'm not sure what you are saying. Are you saying the EA81 doesn't fit in as an example, or that it should fit in because it keeps the clutch disc from wobbling?
  13. Question: Is it a problem that the tip of the transmission main shaft doesn't go into the crankshaft?
  14. The car going inside the sprinter van.... AWESOME! How did he get out once it was inside???
  15. The headers are just the original ones I cut in half (because for some reason the 1100 heads are narrower than the 1300's) so I could put something on the car in case I want to start it before I have an exhaust built. Basically they are temporary so don't worry bout it
  16. Got bored, did some pre-mockup for fun... Let me know what you think! Had a small idea. What about reversing the oil filler tube? Photo of the full drivetrain...
  17. Hooray!!! Thanks again mark Got the valves adjusted (I'm pretty sure correctly) and a few other small things done.
  18. Got back the camshaft and the cylinder heads Yes, the heads are shaved 2mm to fit the Weber manifold!
  19. Emergency!!! I need a set of the 1400 Flywheel double washer thingies for locking down the flywheel! The 1100 ones don't match up, nor do the other 1600 ones I have! I need them ASAP if anyone has a set! (4, one is slightly longer than the other 3)
  20. EA63 4-port heads (IE 1400, IE 1.4L) Wish you would have posted these a month ago, I would have bought them... I just spent a chunk of change on a valve job for the ones I have!
  21. Poop, there are shops that can repair the lip too. Not as expensive as you might thing either.
