Everything posted by Kostamojen
Documented: The 1970 FF-1 Project car...
Kostamojen replied to Kostamojen's topic in Historic Subaru Forum: 50's thru 70's
Just a FYI, I am working on the car, mostly just restoring/painting small parts right now to rebuild the suspension. In the mean time, here are a few pics i've found online recently to tide you over... Oh, and im still mulling over the wheels/tires... I'm having spacers made, but now i've discovered 195/40/16's! -
Thats pretty much what I was going to do. Theres another local place called Tognottis that has more quality aftermarket bits that can help too. I figure i'll check ARP's catalog after I figure out exactly what I need. -
I'm going to try and find some double sided bolts with modified washers to fill the gap. I think it should work, I just have to find the right width bolt with the right thread pattern. -
I shipped one of my drums to RenaissanceMan so he can make some spacers. I'm going to try these 14's and see how they work. -
It was like a slow version of Initial-D with classic Japanese cars Awesome stuff, minus the wreck
Well now I'm starting to lean back to the 14's again, after looking closely at more pics (was going to post this earlier, but the site was down): Notice how the FRONT wheels are pretty much flush with the fender, while the rears are in quite a bit. It appears that the front suspension would work best with a +50 or +45 offset, while the rears need to be much lower, especially dealing with my suspension problem. Now I'm thinking that the spacers in the rear will even things out... This won't work with the 15" superlights since they have the same offset as the Pugs, but custom steelies I could do different offsets for front and rear (say, +45 front, +30 rear) and it would work. -
-The rear fender wells were changed: The pugs were not so much of an issue as the 205/55 tires were. With 195/45's they wont stick out from the side of a 6" wide wheel so they will be pretty much "flush" with the rear fender. And with the modified rear fenders, the suspension will bottom out before the tires hit the fender. The problem with the 15's with the offset that the pugs have (~+25) is the front: Notice how far those wheels stick out even if the fat tires were not on there. However, I could pull the front fenders out, thats not too difficult to do... Now that wouldn't be an issue if I went with the custom steelie approach, since I could have the offset put exactly how I need it. Here is another photo of 14's, specifically the Enkei's on an FF-1. Notice how small they look, and the tires I would be using are even smaller than those: Right now, i'm leaning towards the 15's with custom steelies... -
Alright, im at a critical juncture here... I absolutely need to decide on what tire size to run! I'm still 50/50 on going with 15" or 14" wheels, more specifically I either want to run 195/45/14"s or 195/45/15"s. Yes, I already have the 14" Enkeis, however they still need restoring (which costs money) and I'd have to have spacers made for the rear (which is an issue due to the studs). But the more I see 15" small profile tires, the more I like them. And I havent seen 15"s on any FF-1's. So basically, i've figured that each size has its positive and negative attributes: 195/45/14 tires (with either the Enkei wheels, or custom steelies) Positives - Plenty of clearance to fit them, will allow me to lower the car even more (over 1" of extra lowering due to tire diameter), will accelerate faster due to smaller diameter and lighter weight. Negatives - Will lower gearing ratio and screw up the speedometer a bit, also they look quite small on a car from the photos i've seen. 195/45/15 tires (with the Australian Superlights, or custom steelies) Positives - will fill out the wheel wells nicely, will probably look better on the car, won't screw up the speedo/gearing much. Negatives - more weight, won't lower the car any, with the Superlights they might not clear the front inner fender when turning. So basically, the 15"s (which I know will clear the fenders if I did custom wheels, they are not that large for 15" tires since they have the 45 series sidewall) might be better for driving the car in rough conditions and at higher speeds and the car and might look more porportional, but the 14's would let me lower the car more which might look better too... Either way, I still can't decide Basically, no matter which route I go, I still need to spend wheel money, and I can sell the Enkeis ASAP for cash which will go straight into any of the other wheel options... Thoughts/Opinions? -
Power loss to the drivetrain reduces wheel HP which will effect top speed, but I didn't mean Top Speed as much as high-speed. All things equal, a RWD car will accelerate faster at higher speeds while an AWD car will accelerate faster from a start. Since this car doesn't have that much power, it won't take much to keep the traction from a launch, so RWD will just make it faster all around.
I posted that over in the ebay/craigslist section... I only need a couple parts, and a couple of those i'll have repaired. The driver side glass and the vent covers are all I really need, and i'm contemplating having someone fabricate custom vent covers. -
Well the drums I ordered didn't pan out... They are totally different The hub mounts differently, the height is different, everything is different... Has any other year FWD Subaru had Aluminum rear drums??? Anyway, I did get another suggestion that might help with the wheels. I'll look into that and report back later... -
Gauge, Fuse box, Electrical questions...
Alright, well, I still need to figure out IF I can even use the gauges before I go ahead and do a whole harness and new gauges... I did more searching, and found a couple threads about the "senders" included with the gauges. Aparently some people use adapters for the Water temp gauge sender, since its a BPT and the Subaru one is a NPT or something like that. What exactly are the two threads and whats needed to adapt it? And regarding the oil temp sender, it just needs a re-thread right? So any machine shop can do it? I'm still not certain about the fuel level gauge or the speedo with the mechanical wire yet... I need more information about those. -
Ooh, I think I found something: http://www.painlessperformance.com/webcatalog/largeview.php?SearchField=30301 Its a universal gauge wiring harness! Basically, all the wiring for the gauges if I were to use them Pretty cool. Even does the turn signal indicator lights! I'd just need the fuse box to go with that I guess. -
Just a heads up... The winter 2009 issue of Drive Magazine (by Subaru) has a good article about the Reagan Brat and its restoration Its not up on the website yet, but it says there will be "more pictures" online in the article, so hopefully it will be up soon. Here is a link to the drive magazine website: http://www.drive.subaru.com/
ea71 intake bolts broke
Kostamojen replied to mike20xdc's topic in Historic Subaru Forum: 50's thru 70's
When that happened to mine, I took the heads to a machine shop and had them re-threaded. You can try and do it while its still on whatever its on, but you have to be careful not to drill to much and get into one of the coolant channels. -
I don't know how to figure out how many circuits i'm using... -
Well it looks like there are a TON of painless kits... which one specifically should I be looking at? -
I did see the "painless" fuse blocks on summit. But I didn't see custom wiring harnesses either... And I'm not sure how i'd do that, I don't even know what lengths to put down for anything. -
They have a 3-bolt mounting pattern, which is different. It might be do-able, but the bearings might mount differently too, which would be a more difficult issue. I'd need to see them to be sure though... -
I'm starting a separate thread about this from my FF-1 thread since some of this applies to anyone with a 70's Subaru... Anyway, i'm trying to decide exactly what I want to do with my FF-1 in terms of Gauges and other electrical components. I'm working on mounting locations and such, so I need an idea of what i'm going to do. Price of all this is not a concern, I'm more worried about if it will actually work... Right now, I've got two options: 1) Keep the stock combo meter (gauge cluster) and add at least a tachometer, and modify the stock wiring harness to include the MSD ignition and replace the original (crappy and worn out) fuse box. 2) Replace the stock combo meter with all new gauges; Speedometer, Tachometer, Voltmeter, Water temperature, Oil Pressure, Fuel meter... And replace the original wiring harness with all new wiring along with a new fuse box setup as well. Now, If I were to actually go and replace all the gauges, I have some questions about the specific gauges and how to set them up with an early EA Subaru... Speedometer: For a mechanical gauge, do I need to run a different speedo cable, or do I have to find a different one or modify the original one? Tachometer: No questions here actually, i've done one before, no big deal, and my MSD ignition has a tachometer spot to plug into. Voltmeter: Short sweep or Full sweep? Water Tempurature: This gauge gets its information from the sensor on the intake manifold, correct? Does the OEM sensor work OK for aftermarket gauges? What tempurature range should I look for? 100-250, 140-280, etc. Oil Pressure: Now this is one of the ones i'm concerned about... Should I do mechanical or electrical? I'd rather not have to run an extra oil line to under the dash, but whats involved with either setup and has anyone done it with the early EA motor? I've talked to some people and read that you do need to replace the sensor on the oil pump in order to use an Oil Pressure gauge (since its just a switch and not a temp sensor). What exactly would I need to do in order to do this? Do I need to modifiy the oil pump in order to run the appropriate sensor? Fuel Level: This is the other complicated one... There are SEVERAL types of fuel gauges out there from what I see, and I mean just the electrical specifications. Some say 0 ohms empty, 90 ohms full. 240 ohms empty, 33 full. And several other iterations... How do I find out what the output range is for my fuel level sensor in the fuel tank? Is it listed in the service manuals that I have, or do I need to do something to figure it out? Would I even have to go so far as to replace the fuel level sensor itself??? Alright, those were my questions about gauges... Now lets move on to fuse boxes and wiring in general. My FF-1 is a simple car in terms of wiring, about as simple as it could be. And i'm actually going to make it a bit more simple by not using a couple accessories originally with the car (interior dome light, door buzzer, radio/speaker) and even simplify the engine wiring by using a alternator with a built-in regulator. I will be adding a MSD ignition as mentioned earlier. Anyway, the original factory fuse box was mounted in the engine bay. It was quite small, only had ~5 or 6 fuses in it. I'd like to move it under the dash and use an upgrade unit and keep everything more centralized, any suggestions on what I should use for that? I have found some "fuse blocks" on summit racing and other sites, but since i'm a wiring n00b and probably will need help to do this since I know squat about wiring... Which kind of fuse box should I be looking for? Anyway... Thanks for any help that anyone can provide in advance. I hope this thread does eventually help other people as well about these subjects
Alright, I found some later model brake drums on ebay. I'll find out if they are compatible with the backing plates/etc. when they get here... Hopefully they work, so I can use the longer studs and keep these wheels! -
Has anyone here ever setup an aftermarket Oil Pressure gauge or Fuel Meter gauge on an early EA car? I'm trying to figure out whats required. -
Need Subaru stock check,please
Kostamojen replied to moosens's topic in Historic Subaru Forum: 50's thru 70's
I've had zero luck finding any gen 1 bodywork in inventory. Its usually small stuff like bolts/nuts or engine parts that are availible. All of the unique body parts are long gone. -
found another ff1 for sale
Kostamojen replied to maudsland's topic in Historic Subaru Forum: 50's thru 70's
No photos, and the auction has ended??? -
I found a couple 1/64th scale Subaru's on Ebay that I HAD to have... They just arrived today All 3 are rather accurate for their size.... But I wish I could get a larger model with opening doors and such
