Everything posted by Kostamojen
Documented: The 1970 FF-1 Project car...
Kostamojen replied to Kostamojen's topic in Historic Subaru Forum: 50's thru 70's
Well, putting the wheel under the hood (combined with the FWD drivetrain) in 70 gave this car "class leading" trunk space... But I don't have a key to open the trunk yet Gonna have to do a bunch of work to even get in there to unbolt the latch... -
I can't get in the trunk yet without a key, but it looks like a few things came with the car... Now here is the biggest problem so far that i've found... So the car obviously needs A LOT of work. Ill start cleaning it out tommorow, then seeing what I can do about the body. Ill have to find a shop that can repair that kind of body work. Luckly the roof and doors seem in good shape, unlike the '78 I worked on... -
'70 FF1 Coupe JY N/E Calif.
Kostamojen replied to worknwood's topic in Historic Subaru Forum: 50's thru 70's
Got the car a little while ago! Thanks for all your help again worknwood!!! It definatly needs some work... Ill post some pictures in a new thread here shortly. -
What's better the Pug 14s or the 15s??
Kostamojen replied to Crabman's topic in Historic Subaru Forum: 50's thru 70's
205/50/15's No rubbing /thread -
Anyone else familiar with the 1400's?
Kostamojen replied to moosens's topic in Historic Subaru Forum: 50's thru 70's
Ya, I noticed the radiator hose routing in the service manuals... Seems like it might be easier just to convert it to a custom radiator with fans rather than modifying the intake manifold... But at this point in time, I'm just speculating and seeing what options are out there. So ya, this info helps a ton -
Hmm, interesting... So the easiest way to run the EA71 "dry" shortblock on the FF-1, I'd need to have: EA71 Shortblock EA63 cam EA63 heads EA63 intake manifold (or is the EA63 intake manifold interchangeable with the EA61's?) Swaped EA63 bellhousing (or will the EA61 bellhousing work?) Spacers for the flywheel (or is that not needed keeping the EA61 transmission?) -
Awesome! I just might take you up on that at some point Thanks! -
Heres a few more models to choose from: http://www.toyeast.com/v3/catproductlist.asp?cat_id=391&clvl=4 -
Updated list, since I cant edit the previous post... X Displacement Engine code Horsepower (HP @ rpms) Torque (ft lbs @ rpms) Compression Features Years ModelsAA 356cc EK31 16 @ 4500 @ 3000 6.5:1 2-stroke Air-cooled 1958-69 360BB 356cc EK32 18 @ 4700 @ 3200 6.5:1 2-stroke Air-cooled 1961-70(?) Sambar* 1000 EA52 55 @ 6000 @ 3200 6.5:1 2bbl OHV 1966-70 10000 1100 EA61 62 @ 6000 63 @ 3200 9.0:1 2bbl OHV 1970-71 FF-11 1300 EA62Sports 93 @ 7000 76 @ 5000 10.0:1 2x2bbl OHV 1971-? FF-1 1300G Sports1A 1300 EA62 80 @ 6400 73 @ 4000 9.0:1 2bbl OHV 1971-? FF-1 1300G2 1400 EA63A 61 @ 5600 69 @ 3600 9.0:1 2bbl OHV 1973-74 2A 1400 EA63E 58 @ 5200 68 @ 3600 9.0:1 2bbl OHV 1975 2B 1400 EA63S 58 @ 5200 68 @ 1500 8.5:1 2bbl OHV 1976 3 1600 EA71 67 @ 5200 81 @ 2400 8.5:1 2bbl OHV 1976-79 3A 1600 EA71 65 @ 5200 80 @ 2400 8.5:1 2bbl OHV 1976-79 4X43B 1600 EA71 68 @ 4800 84 @ 2800 8.5:1 2bbl OHV 1980-82 3C 1600 EA71 69 @ 4800 86 @ 2800 9.0:1 2bbl OHV 1983-84 4 1800 EA81 72 @ 4800 92 @ 2400 8.7:1 2bbl OHV 1980-82 4A 1800 EA81 73 @ 4800 94 @ 2400 8.7:1 2bbl OHV 1983-84 Brat/2dr GL4B 1800 EA81 82 @ 4866 103 @ 2800 9.5:1 2bbl OHV 1985-87 4DR/Wagon DL4C 1800 EA82 94 @ 5200 103 @ 2800 9.0:1 MPFI OHC 1985-87 4DR/Wagon GL-104D 1800 EA82 90 @ 5600 101 @ 2800 9.5:1 SPFI OHC 1985-94 3DR/4DR/Wagon/Loyale4E 1800 EA82 84 @ 5200 101 @ 3200 9.5:1 2bbl OHC 1987 3DR/4DR/Wagon4F 1800 EA82 84 @ 5200 101 @ 3200 9.5:1 SPFI OHC 1987-89 4DR4G 1800 EA82 97 @ 5200 103 @ 3200 9.5:1 MPFI OHC 1987-91 XT5 1800 Turbo EA81T 95 @ 4800 123 @ 2000 7.7:1 Port Inj. 1983-84 4DR/3DR/Wagon Turbo5A 1800 Turbo EA82T 111 @ 4800 136 @ 2800 7.7:1 MPFI OHC 1985-86 4DR/Wagon/XT Turbo5B 1800 Turbo EA82T 115 @ 5200 134 @ 2800 7.7:1 MPFI OHC 1987-90 3DR/4DR/Wagon/XT/LoyaleTurbo6 1200 3cyl EF12 66 @ 5200 70 @ 3200 9.0:1 2bbl 1985-93 Justy6A 1200 3cyl EF12 73 @ 5600 71 @ 3600 9.1:1 MPFI 1990-94 Justy7 2.7 6cyl ER27 145 @ 5200 156 @ 4000 7.7:1 MPFI 1988-91 XT-68 2.2 4cyl EJ22E 130 @ 5600 137 @ 4400 9.5:1 SOHC 1990-94 Legacy8A 2.2 4cyl EJ22E 135 @ 5400 140 @ 4400 9.5:1 SOHC 1995-96 Legacy/Impreza8B 2.2 4cyl EJ22EZ 137 @ 5400 145 @ 4000 9.7:1 SOHC 1997-98 Legacy/Impreza8C 2.2 4cyl EJ222 142 @ 5600 149 @ 3600 9.7:1 SOHC 1999-01 Legacy/Impreza9 2.2 Turbo EJ22T 160 @ 5600 181 @ 2800 8.0:1 SOHC 1991-94 Legacy Turbo10 3.3 6cyl EG33D 230 @ 5400 228 @ 4400 10.0:1 DOHC 1992-97 SVX11 1.8 4cyl EJ18E 110 @ 5600 110 @ 4400 9.5:1 SOHC 1993-96 Impreza11A 1.8 4cyl EJ18S 115 @ 5600 120 @ 4400 9.5:1 SOHC 1997 Impreza12 2.5 4cyl EJ25D 155 @ 5600 155 @ 2800 9.7:1 DOHC 1996 Legacy12A 2.5 4cyl EJ25DZ 165 @ 5600 162 @ 4000 9.7:1 DOHC 1997-98 Impreza/Forester, 97-99 Legacy12B 2.5 4cyl EJ251 165 @ 5600 165 @ 4000 9.7:1 SOHC 1999 Impreza/Forester12C 2.5 4cyl EJ251 165 @ 5600 166 @ 4000 10.0:1 SOHC 2000-04 Legacy/Impreza/Forester/Baja12D 2.5 4cyl EJ253 168 @ 5600 166 @ 4000 10.0:1 SOHC 2005 Legacy/Impreza/Forester12E 2.5 4cyl EJ253 163 @ 5600 166 @ 3600 10.0:1 SOHC PZEV 2005 Legacy PZEV12F 2.5 4cyl EJ253 173 @ 6000 166 @ 4400 10.0:1 SOHC i-AVLS 2006-07 Impreza/Forester12G 2.5 4cyl EJ253 175 @ 6000 169 @ 4400 10.0:1 SOHC i-AVLS 2006-07 Legacy12H 2.5 4cyl EJ253 170 @ 6000 170 @ 4400 10.0:1 SOHC i-AVLS 2008+ Legacy13 2.0 Turbo EJ205 227 @ 6000 217 @ 4000 8.0:1 DOHC 2002-05 WRX14 3.0 6cyl EZ30D 212 @ 6000 210 @ 4400 10.7:1 DOHC 2001-04 Outback14A 3.0 6cyl EZ30D-R 250 @ 6000 219 @ 4200 10.7:1 DOHC AVLS 2005-07 Outback/Tribeca15 3.6 6cyl EZ36D 256 @ 6000 247 @ 4400 10.5:1 DOHC AVCS AVLS 2008+ Tribeca16 2.5 Turbo EJ255 210 @ 6000 235 @ 3600 8.4:1 DOHC AVCS 2004-05 Forester XT/Baja Turbo16A 2.5 Turbo EJ255 230 @ 5600 235 @ 3600 8.4:1 DOHC AVCS 2006-08 WRX/Forester XT16B 2.5 Turbo EJ255 250 @ 6000 250 @ 3600 8.4:1 DOHC AVCS 2005-08 Legacy GT/Spec-B17 2.5 Turbo EJ257 300 @ 6000 300 @ 4000 8.2:1 DOHC AVCS 2004-08 STI
Ebay is blocked here at work for me. Is that an ebay listing for the FF-1 die-cast model? Anyway, Ill probably be interested in that front bumper, but I really do need to see the car before I can start figuring out what I need -
I really need a good close look at the car to get an idea of what it needs... The front bumper looks toast. Driver side window will need replacing. That rusted fender may be save-able, I doubt a replacement will ever show up anyway... But I'll make sure to send you the list ASAP, and I don't have any expectations for ETA or anything of the sort so don't worry about that. Oh for sure! I owe darrell big time for his help with this I was fully prepared to rent a truck and trailer and take a day off to pick up the car during the yards business hours, but workinwood's offer to pick up the car for me and deliver it was WAY more than I could have ever asked for! This project is 100% a result of his efforts, no doubt about it! :clap: -
Has anyone else noticed you can't do a search for "ff-1" on USMB??? -
:banana: -
19 in the inventory as of today.
Sorry to bump this... But I was informed by my shop foreman (who even worked for Subaru back in the 80's) that it was common procedure to replace the EA6x shortblocks with EA71 shortblocks so they wouldnt have to deal with the sleeved blocks... Ill see if I can pull more info out of him, as i'm thinking this might be a good route to go with the EA61 in the FF-1. -
No, I havent forgotten you I plan on making a short list this weekend after going over the car thoroughly, then cleaning up the car as best as possibly before making a full list. I do know the first thing that it may need are those "vents" on the d-pillars... Those are obviously missing -
My shop foreman here at work (Maita Subaru) just handed me the original FF-1 Body and Engine service manuals! -
Ya, I was kind of concerned about that fire when I first read you were up there at Almanor... We had a few days down here in the valley last week when the smoke from that fire completely filled the valley like a thick layer of fog, it was quite horrible to be in, hard to imagine being that close to it. Thanks for all your help Darrell It was my goal as well to save this car as quickly as possible. I promise to everyone else that I will be keeping a detailed log including LOTS of photos and videos of the car from day one. After all, a car like this if for everyone on the forums to enjoy, its just that important! -
I sure will, ill update my for sale thread -
I've actually been wanting to visit that area of the state, never been there before... I'll take my camera for some photography of course -
I've got the money right now, its the transportation I need a hand with (junkie is the man btw) And if I do somehow manage to get the FF-1, my wagon will be on mega-clearance to make room of course -
I'm going to probably head up there this weekend, see if I cant save it... Waiting for worknwood to get the info from the yard up.
