Kostamojen
Everything posted by Kostamojen
  1. FYI, the 4EAT in 1rst or 2nd worked just fine doing plow duty these last couple of days ... I saw some front wheel spin for a second, but it wasnt bad. I think the 4EAT would be nice with a front LSD.
  2. Thats not the first, not even the third Subaru to roll on Mt. Hamilton...
  3. With the old school MAF intake, you should have just made a 90 degree elbow from the throttle to the MAF and then had the pipe go out at a higher location on the fender and maybe have the airbox on the outside of the car...
  4. Well mine is a "historic" scoob, so its a little different, but I have the 15"s + 205/55/15's: http://community.webshots.com/photo/166896604/458793324uMyRNS http://community.webshots.com/photo/166896604/458792973jibXAC
  5. The worst your speedo would be off with wider tires (but with a 15" wheel with lower profile tires) is probably less than 5mph at 70mph. But since my speedo cable is fubared, I cant tell you exactly what its like. I can tell you that with slightly taller tires, your gearing is slightly taller as a result, which means you do lower RPM's at speed, which is good for mileage and means you can go a touch faster with the 4-speed.
  6. Wow, great info I'm glad to see someone try the Scorpion springs. Now i'm really curious about a body lift and taller tires in conjunction with that setup...
  7. Wow, that is awesome! Makes me want to lift my Impreza eventually But now you need to splurge on an AA lift kit and get another couple inches
  8. Rockin :D Explorers are nothing special. I've seen dozens of them strewn across the sierra's during winter in pits, upsidedown, sideways, etc.
  9. 205/50/15's, no rubbing issues at all (not even close). Plus, the car handles VERY well now, I was surprised (I can throw it into a corner like with my Impreza and it doesn't squeel at all and just turns in nicely). The car also looks much more agressive and just plain more cool Pics: http://community.webshots.com/photo/166896604/458793324uMyRNS http://community.webshots.com/photo/166896604/458792973jibXAC
  10. Hmm, I thought the ones I found at the PnP were in bad shape, but those are just really bad! Try some Naval Jelly (rust remover) and a gridner or something to remove the hard rust. Get a metal pipe cleaner for the inside (thats what I used). And repaint them when you are done.
  11. OMG that thing is awesome!!! Too much $$$$ though... (well not really, but I can't buy it )
  12. Get a custom exhaust made from a muffler slop like they said. Shouldnt cost much, $200-250 or so. You can have it made with whatever muffler you want, any style you want, a resonator or not, basically anything goes since we don't have cats... As for the radiator, order a new one or upgrade to an 80's radiator from a junkyard. (I lucked out and found one in PERFECT shape from a late 70's wagon at a junkyard)
  13. Hi guys, Just wanted to parlay the news that Richard Burns had a featured trubute on todays episode of Top Gear (12/04) Here is the link to the bittorrent of the episode (350mb): http://www.finalgear.com/downloads/topgear/7/4/
  14. Thats why I said excluding extreme offroading, IE climbing non-road hills and such. The AWD will actually work better for snow driving, and loose terrain applications in on-road situations as well as dirt/gravel/etc. roads, and I specifically stated the VTD Auto tranny because the regular 4EAT is nothing special.
  15. I like your option #1. A lifted forester can do about anything, and if you get a VTD auto tranny from a Baja or WRX in there, you will have a true AWD system with a planetary center diff that will probably outperform the EA82 D/R in most anything but the most extreme off-roading situations.
  16. NICE FIND!!! Ya, its a dog, but its still fun to drive around... You wont get stuck anywhere at least, but watch out for bay area freeway driving Anyway, I agree with alot of suggestions here, especially if you don't have a limited budget... I'd go with either a fuel injected 1800 and 5-speed tranny, or screw it all and throw in a whole EJ22 drivetrain from an early 90's legacy or Impreza like some folks have done with brats (check the retrofit forum). For suspension, theres not much that can be done easily in terms of bolt-ons... Maybe replace the shocks, but there arent many options for upgrades unless you have something custom made. Personally, I found when I got my new tires (205/45/15's) on with my new wheels (15" pugeot wheels) the handling improved greatly just getting a bit more rubber under the car... (latest pic of mine with the wheels/tires: http://community.webshots.com/photo/166896604/458793324uMyRNS ) For the brakes, I just replaced my front rotors and pads. Worth it in terms of getting the car to operate properly when braking, but if you have major brake problems you might have to replace the master cylinder as well as the rear drums... As for the rust, I see you have your own shop and experience, so ya, it sucks, lots of work ahead, LOL!!! BTW, let me know if you can get it past emissions, I haven't been able to yet :-p
  17. I want more of a go-anywhere-and-never-get-stuck off-roader, rather than a die-hard serious rock crawler... But anyway, here it goes: My '95 Impreza L with the 2.5 motor already in it AA 4" body lift kit Outback struts Scorpion springs Some infamous super-swampers (wheels, undecided...) Upgraded bushings and mounts all around (already have a few of those) Baja XT 4.44 VTD 4EAT modified with a front LSD along with the rear LSD Upgraded torque converter Tranny oil cooler Full under-body armor Roll cage Custom snorkel of course Exhaust routed to a higher point on the car (for water) Sealed chassis (water, there are a few holes that need plugging) Water-protected battery and other engine area components Gutted interior w/ rubber mats (for cleaning ) Roof mounted spare tire Extra luggage rack on the trunk Extra fuel cans located in the trunk I guess... What else am I missing?
  18. Whats with the clean historic subies showing up in Portland? LOL! Very nice...
