It makes a sense! Yes, I used that info sheet. You're awesome! You answered to my question.
I reviewed my test results and did one more test after the transmission temperature was lowered to 80 deg F. With a new wire connection to the temp sensor outside, I measured voltage between two wires with my little voltmeter. The temp sensor resistance is 1500 ohms, the voltage read 1.2 volts when the volt range is 9V. When I switched range to 1.5V on my voltmeter, it read .15 volts. Something wrong. The volts were supposed to be about same in two different ranges. I tested a 1.5 volt battery with my voltmeter and the reading was same in the both range. I suspect current is weak? I swapped TCM and the result was the same. If you read my replies/answers in justanswer.com, it's same result. (9/6/09 7:38pm) An expert asked me to measure voltages that were inputs to TCM and they seem ok. I think the connector to TCM is bad or maybe both TCM's bad. I could take the cover off and measure some points inside to test the terminal connection. Is it required that the TCM box is grounded all times?
Is there any variable or control to vary the voltage to the temp sensor?
Tomorrow is my appointment with Subaru service for my car. Maybe I leave it to them.
