incognito
Everything posted by incognito
I'm getting about 28 in town and 32 highway
EA81T Failed Smog: High HC @ Idle...
incognito replied to TheSubaruJunkie's topic in Old Gen.: 80's GL/DL/XT/Loyales...
old oil, poor pcv valve, and poor charcoal canister can do it too. -
(prizeless) Contest: Guess the Problem
incognito replied to NorthWet's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I'm blaming the owner/operator -
While the engine is out.....
incognito replied to singletrack's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I ran a kevlar clutch, operated like a stock one (same grabbing ability).. but you can roast, and roast, and wear and tear, and it still works -
I still need that skid pan spacer (3" EA82)
If they reproduced a EA82 car today
incognito replied to torxxx's topic in Old Gen.: 80's GL/DL/XT/Loyales...
EA is outdated for a reason. -
Funky whatchamacallit on my radiator.
Eh noah beat me to it.. -
PENRAY-SUPER-X Engine/fuel Cleaner
incognito replied to Bro's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I would recommend having a fuel injection service done.. Basically the car runs off these cans for a few minutes and cleans everything out -
I was considering eliminating both cats and stock muffler in place for 2" pipe all the way back to a high flow muffler.. Opinions I dont want: (removing catalytic converters, yes I know they are there for a reason, but I want the extra 5-10hp instead of being a non-polluter, sorry. I may run with a highflow monolith cat, but for now, I'm not concerned with that in this post.) Opinions I do want: Should I bend the pipes like the stock exhaust for highest effeciency or should I make my "Y-Pipe" bend as little as possible and try to make the piping as straight as possible? Thanks for your opinions.
Wagon wisdom. Buying advice.
incognito replied to JLantz's topic in Old Gen.: 80's GL/DL/XT/Loyales...
88 GL wagon - SPFI and D/R tranny, reliable EA82. -
Brat/EA82 interchangeability.
If you already have the EA82 parts, try it.. -
No, thats definately not the reason.
Its not that great down there..
yeah those rubber boots are a must if you ask me, i have a set, and i used them as a bar to hook up my antenna whips.
I am working on this currently.. Just for fun, I'll dyno my car before and after. I think I have figured out a nice way of making one also.. I'll keep this updated.
What about the spongy pedal? does that go away?
What CAIs are you using?
incognito replied to Phaedras's topic in Old Gen.: 80's GL/DL/XT/Loyales...
i used the stock intake to the MAF, then adapted the k&n cone intake to the MAF with an injector cap.. The k&n filter protrudes into the fender approx 2". part number: RX-3990-1 -
something wicked this way comes caution for dialup get a snack
incognito replied to oddcomp's topic in Subaru Retrofitting
Looks good. -
I just bought my 88 GL wagon with SPFI... made that conversion easy :cool:
How did you mount the leaf springs to the subframe?
I'm sort of toying with the idea to drop in a turbo system on my EA82 SPFI block (9.5:1 compression).. Besides the exhaust and turbo itself, what other things am I going to need to make this happen? Boost controller? What about hooking up oil lines and coolant lines? Thanks.
O2 sensor placement???
incognito replied to Petersubaru's topic in Old Gen.: 80's GL/DL/XT/Loyales...
this is correct. -
Help...Headlight Is not working
incognito replied to alaskansubaru's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Stay away from these. -
looks like I have a couple of members to meet.
