larrykjr
Location
concord
Vehicles
I Love My Subaru
larrykjr's Achievements
Member (2/11)
0
I dropped off my 01 OBW 2.5L w/114k to my (trusted) Subie specialist mechanic for HG's, timing belt, etc and he found some nicks on the gasket surface of the head on the driver's side. Looks like the HG's had been done before and they nicked it somehow. They are fully covered with the gasket when you lay it on there, and the concerning part is that the closest scratch is about 1/16'' from the right combustion ring. It's pretty shallow and he says that you can barely catch it with your fingernail. The deeper one to the left is far enough away that I'm not too worried because it's far from the cylinder and the coolant jacket and this motor has the open deck so the other surface of the gasket is floating. What do you guys think? I'm gonna keep the car and want to do it right but the cheapest best way. About $100 to machine the heads, or buy a used head, or leave it alone?
Help! I was removing the CV axle in my 95 Legacy AT FWD w/ 96k, and when I was taking off the ball joint I yanked and the output shaft came out from the tranny! It's connected to the cv axle because I meant to take out the spring pin but hadn't gotten to that step yet. It has a C-clip on the splines that go into the front diff. How do I get the shaft back in? Is there hope?
Today my 98 OBW has been hard to get into gear and grinds into reverse like the clutch is going out. Got it to Walmart and turned it off to look at the actuator arm on the hydraulic pump thing that the clutch reservior line goes into on top of the tranny. I manually moved it and it made it worse-the pedal hits the floor and won't spring back. I have to manually pull it up. It comes up without much effort and will stay there but gives no resistance as if I push it down and it stays on the floor. What's the deal? Has that happened to anyone? I need to get this thing home!:-\ It started grinding into reverse over the past 3 days but the other gears have been fine. Could the oil separater plate have leaked onto the clutch and trashed it? Would that affect the spring/resistance of it? Thanks!!!
I have read the 2.2 swap threads and wonder if anyone has swapped in a 2.2 into a 98 forester? I just bought it with a seized motor and found a 95 2.2 L w/EGR and wonder if it will swap in? I know in 99 the Foresters got the SOHC Phase 2 2.5L and the 8 bolt pattern trans but in 98 I can't remember if it's still the 4 bolt pattern on those cars. I imagine so since 98 had the DOHC 2.5. :-\ Anyone know? Thanks!!! I wonder if it would feel underpowered since the Foresters seem to be geared higher than the OB's...
Thanks for the links to the Headgasket replacement by Skip. I ended up getting that 98 OBW and am picking up a '95 2.2 from an auto trans this week to swap in. Trying to muster the courage to do it myself. I'm pretty handy but I don't want it to drag out...I also got a 98 Forester AT with a bad motor. Should I swap in the 2.2 to the Forester or put in the 2.5 from the OBW after doing the HG? Confusing I know, at least you guys know what I'm talking about.
