About methusalah
- Birthday 10/05/1965
Gender
Not Telling
Location
Tucson
Interests
Subies, Landcruisers, VFRs
Occupation
USG
Vehicles
89 GL turbo wagon
methusalah's Achievements
Advanced Member (3/11)
0
Some pics of the hatch. 56k go get another... Coke.
methusalah replied to TheYeti's topic in Members Rides
Wow..it is very nice...I have one in white and don't think I'll ever part with it! -
Broken thermostat housing bolt
methusalah replied to methusalah's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Thanks for all of the advice/help...I actually considered option #6, although with a clamp instead of vice grips! I thought it might be an OK temp fix just to get the car moving again... Cheers! -
Nope...it's located on the top left/passenger side of the engine... -
Seems to be broken with some still above the block...I haven't tried anything with it yet since I'm concerned about causing more damage. -
Help! I managed to cross thread the bolt when replacing the t-stat in my 89 turbo wagon...tried to remove it and the bolt snapped...any help/advice (I know, I know, replace with 2.2...) would be great. Eventually I'll find a 2.2 to swap in with a d/r trans yet for now I just need it back on the road. Thanks
hitachi carb - issues after partial rebuild
methusalah replied to belacane's topic in Old Gen.: 80's GL/DL/XT/Loyales...
So...I have a 81 dl 4wd wagon that needs the card rebuilt...the accelerator pump is leaking right around the little cone shaped bellows/shaft area. Where can I find the bits or a kit to rebuild it? I know the hitachi isn't the best but I'm unwilling to get a weber. Thanks! -
OK, some of you may remember my 2004 Imp project, bought car with broken timing belt, replaced t-belt, etc...tried to get it to start, no joy. It turns over and I don't hear any weird noises...if the valves were bent, what woould/should I hear as it turns over? Also, if it should or is supposed to start and run, albeit roughly, what else might cause it to NOT start and run? There's fuel in it, only about 1/4 tank...fuel pump or filter issue? Any help/advice would be greatly appreciated...I'm moments from ordering a used running motor and calling it a day... Thanks, Steve
Yeah, it was a good deal - overall car is in really great shape...except for the huge amount of bumper stickers on the back! I put a new belt on it along with replacing the h2o pump, tried to get it to start and it turns over and doesn't make any popping noises...but won't start...gonna check fuel and some other stuff just to be sure...thanks.
OK-the 2004 Impreza TS wagon I picked up for $700 (cause PO had broke the TB...) looks like there is some damage, shocking I know. A local subaru expert recommended just pulling the old motor and putting in a 'new' one (used) vs. pulling the old one and rebuilding the heads...Any one here have some advice or thoughts - I think I'm gonna need to pull the motor either way - I know pulling the heads in the car is possible, I'm not sure if I'm up to that level of frustration (hard to reach bolts, etc.)
