Seawolf
Location
Sarasota
Vehicles
I Love My Subaru
Seawolf's Achievements
Member (2/11)
0
So try ro swap on a 2.2 intake ICV from forester intake, and other thing may be swaped from forester intake, or you just can possibly use yours 2.2 engine harness. I think you can get it done wihout getting other intake. Also, i belive 2000-2001 intake will not bolt up to 97 ej22, i might be wrong, but i think 2000-2001 intake has same bolt pattern with ej25.
Hmm.... 1 test drive is done with older ej22 swap in 99 dohc ej25 outback . Exhaust gas smells wrong(i know i have a lot of fuel in the exhaust, but car was running for more than 1 hour by now). So i think im running too rich. Anything i can do about it? Also car overheats(hope headgaskets is allive). Besides that, car run like a champ. Tommorow will try to change injectors again(all of them now) and see what is the nature of overheating. Let me know what yall think about "stincky exhaust"?
nope. never had a problem with fitting aftermarket rotors....well of course wehen i was getting wrong part# due to my or salesperson mistake:). sure i had problems with fitting "Chinese/Taiwanian body parts":lol:. But anythig else was fitted perfectly. Also cheap stuff is "cheap". I always prefer good aftermarket parts, and belive me they r better(with exeptions of course).
Looks like im figure it out. Disconnetcted #2 'n' #4 fuel injectors = no change, so i disconected spark plugs #2 'n' #4 = no change. Got the spurk plugs out and both of 'em wet. When i was trying to mess with a #1 n #3 cyl. the car was shutting off right away. So my guess was - no compression in #2 'n' #4, ran a compression test - compression is near perfect. Should i bet money i have meesed up injectors?(sure i know this EJ22 was sitting for at least 3 years). Tried to unclog them putting 12v straight - didnt make any change. So i think this swap is possible just gotta find out whats else need to be done.Its still may be ECU issue and ECU wont give signal on injectors #2 'n' #4 at right timing time. But at least i pointed my problem. Will keep it up with my progress on it.
well im going to get some gas. and will stick radiator in the car, so i will be able to run for a while. There is a lot of junk in a gas tank:eek:. Will see if it helps. Now im gettin p0135 and p0403 codes. well 0403 thats what i suggested and sure i dont have EGR valve. But will oxygen sensor make car running ruogh? or might be its for not having EGR valve too? My thought is becase by deleting EGR im getting waaaaay different exhaust gas structure. Let me know gyus what you think about it?
oh yea i did make sure bout sprokets r same, at least same amount and location of that teth on a back of cam sproket.Im running it on a ej25 DOHC ECU. That was a reason i swaped original engine harnes to ej22. Also now after i corrected timing belt, changed spark plugs and ran it for about 3 min. it idels better and acceleretes pretty good now, but still kinda funny. Ill try to replace gas from gastank cuz aint much in it right now and car was sitting for about 8mo. till now. Will see how it goes. And ill let you gyus know if this swap possible at all. Im sure i can get to run right on ej22 non EGR ECU, but dont really feels like going thru swaping to obd1 rouitine. BTW reason for this swap is only because i had older ej22 for free, so decided to see if i can get this one to work before spending ton of $.Original EJ25 DOHC was run out of oil by previous owner and spun a bearing i guess. I know i can swap heads, but one more time - im trying to see if ill get this engine to work the way it is. Thanks
