Everything posted by Dirk
All vacum hoses present and correct.
Dude, with so much unsealed road in this country you can have heaps of fun without bothering about the handbrake! I agree with Tom, flick it into 4wd and hit the dirt tracks.
Where is your ash tray? Mine is on the top of the dash. I just remove the tray and wedge my morning coffee in the hole. Only trouble is the heater control linkage is under there. Occasionaly when I have a slow morning (brain still not functioning) I flick the heater control and the linkage sends the cup flying!
Good Call! The secondary valve was not fully opening. Will let you know how this has affected things just as soon as I can get out by myself.
Cheers Rob. No cat but it is the classic pea shooter exhaust. Maybe its being a little restrictive but I guess subaru knew what they were doing when they designed it. I've been playing with the timing a lot lately but have found it quite difficult to tune by ear because of other noises confusing me. Like I said, it feels like its dragging its heels at high speed. I wonder if then the timing is either too advanced and slowing the pistons down or too retarded and not putting enough bang behind the pistons. I'm also curious about fuel/air ratio. My spark plugs are very clean at the moment. Perhaps too clean.
Firstly, Hello to all on this forum! Dunno why but I have been posting a lot on the 80s forum but since my 1600 dl is in fact 1979 I think I should hang around here more often. Anyway, I'm having trouble getting the old girl to do much over 120k (75mph) on a flat straight. Not long ago I would have been able to cruize at that speed and if I put my foot down get up to 135k (83mph) Iv'e done a lot of work to the engine lately and probably farted around with the carb to much but generaly she is in fine shape. She starts first time on even the frostiest mornings which suggests to me that I can't be far away but I can't help feeling she has a lot more to give. Coments please on where to direct my attention and why. Or am I just asking too much from her Some details to help: Recently rebuilt engine. New ignition system (bar the dizzy) Timing at 8 degrees Hitachi Carb (cleaned and rebuilt to the best of my abilities) Recent compression test perfect Cheers Dirk PS I did get her up to 155k (96mph) yesterday but it was down hill and I got the feeling that the engine was actualy stopping the car from running away from it any further. PPS Naught to 100k (62mph) is fine at somewhere between 13.5 and 14 seconds so the power is there, I just can't find it at the top.
Clutch Cable replacement blunders
Dirk replied to gadberry's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I've got that book! I think its great. Fills in most of the gaps from my Haynes manual. Not sure about all the Star Trek references though. The index is a funny read. -
Strange ea82 overheating/steaming
Dirk replied to LuberJack's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Good on ya mate! Now that the stat is back in you will find it warms up a lot quicker from cold. Heater will work better too. Probably not a bad idea to flush the system some time and top up with new coolant. Does she still rough rough first thing? Track down your manual when you can and start checking the obvious things. It doesn't cost any money to check if all systems are set correctly, just a little time. Enjoy! -
BTW, if it is a head gasket issue you may well find that the coolant errupts from the radiator when the cap is off. But for heavens sake DON'T try this when the engine is hot! -
Don't forget to 'Burp' the system once its all back together again or she will overheat for sure. Have you checked the condition of the engine oil yet? -
Did you see the one on trademe in Aukland a few weeks ago? I was pretty keen but I think the wife would have divorced me. (which is a bad thing cos she's still hot and looks after me pretty good)
Leaking front windshield ea81
Dirk replied to ()__1337_CRAYOLA__()>'s topic in Old Gen.: 80's GL/DL/XT/Loyales...
Cool! -
OK. Then run the engine without the thermostat and see if the temp still goes up. At least you can eliminate a possibility, even if you do have to get a new one regardless. -
I'm guessing the gasket failed due to abnormally high water pressure and temperature. Could be head gaskets. Check the engine oil. Does it look normal (thin and black) or is it creamy coffee? If it looks OK then I wonder if there is an air lock in the cooling system or is the therostatic valve stuffed? Top up the water and run the engine with the heating on full and the radiator cap off. This should 'burp' the system of any air. You may have to do this a couple of times if there is indeed air in the system. If the engine is still overheating then I would turn my direction to the thermostatic valve or the water pump. The thermostatic valve is under the water pipe fitting in the picture (the one thats leaking). Unbolt the fitting (when the engine is cold) and pull out the valve. Remember which way up it goes because it only works that way. I'm not sure what it will look like if it is broken but someone will be able to tell you. -
Robert Jopson, Cromwell Auto Recyclers. A great source for gen1 parts. He is quite the subie fanatic and also a well knowen face at speedway tracks. Actually he used to own my car. I like him a lot and he has always been good to me (if a little kurt at times), but he does have a reputation for being a little difficult at times. I hear he was banned from racing last year because he verbaly abused a track marshal. He has a couple of spare twin carb engines too but is reluctant to part with them right now. Bummer.
I think I've sussed it! Spoke to a fella who has a few of these engines and he said: Yes they do have 'hotter' cams, bigger valves and higher compression. Gold star to those who suggested as much. He also went on to say that retro fitting a dual carb on a stock engine will only cause it to burn more fuel. Although it would appear that other people on this forum have had other experiences with this. More opinions on this welcome! Unfortunately this is about as much info as he was willing to give. I get the impression I gets tired of dishing out free advice all the time. Shame, because he could be a real asset to this forum. Cheers to all who passed comment.
Sorry can't help. But thanks for making me laugh. I suspect it could be the ball joint at the bottom of the shifter but I have no experience with you model. Access to mine is from the top.
No Tom, this is the last rebuild from 2 years ago. Still searching for a new one to have acrack at.
Cheers. Yes. Its Sprite Green.
Oops! Cheers Tom. Sorry Thomas. Altough I'm sure they continued the EA71 into the Eighties. ??
Did you actually read this before posting? You managed to contradict yourself in the same sentence. Also, can you explain to me why you think this is the wrong forum for my question?
In my experience the only perminent fix to this is to have the screen removed and re-installed. Prefereably with new rubbers. I find it strange that you are having toubles getting a pro to do this. A company like that wouldn't get my business. -
sorry. So which one should I post in?
Its just a water mark after washing the block for the hundred time. Looks like I didn't wipe it down properly. I cleaned everything by hand.
