Bash
About Bash
  • Birthday 06/04/1961
  • Location
    Amarillo Texas
  • Occupation
    Fast Food
  • Vehicles
    Wagon, Brat
Bash's Achievements
Advanced Member
Advanced Member (3/11)
  1. That SJR kit I bought went in easy and works great. I am very happy with it.
  2. 4" EA82 ,every thing fit. All parts included. Answerd all questions.
  3. Bash
    4 inch lift
    I did my SJR 4" lift By myself with jack stands and a floor jack. Didn't have to remove the engine. I did take off the exhaust and driveline, also disconnect the shifting linkage and drain the radiator. I had to cut off about 1/2 inch of the bottom rad hose the top hose still fit with no mods. I did the rear first. Then the front.
  4. i was just wondering what those wheels came off of on your black wagon?
  5. Bump when will you post your EJ swap write up. on the other post?
  6. Thanks for the reply. It was an easy fix. I needed a ground to the body I only had a ground to the engine.
  7. My 86 subi is running great. For a while as I drive, the stereo would just shut off then come on. I thought it was bad I was going to take it back to best buy. Driving it at night I saw that the head lights were dim, my temp gauge was in the red, stereo was off and the volt meeter wa undr 8. When I pushed the clutch in to pull over every thing came to life. so I let off the clutch. dim. If i just rest my food on the clutch all works well. I looked at the cable and petal no wires are in the way. any ideas on the problem?
  8. The cable has to be OVER the wheel - that won't work. Try it and you'll understand . GD This works great! This is what I mean about a backwards carb. On the other carbs have the lever on the other side. This one pulls twards the rear not the front.
