gvr4737
Everything posted by gvr4737
  1. Nope the front cat exploded and clogged up the whole exhaust fix = gutted both cats and ran a de fouler on the 02 sensor soo its legit
  2. i used ngk spark plugs gapped correctly and oem replacement wires from advance auto... i may still have the stock set i can try if u think this could be it i put probably 200 miles on after wires before this
  3. so finally got it to throw a cel again.. it thru the colde p0301 and p 0302 my guess is i have a grounding issue... im gonna buy all new ground cables and re do them anyone else got an idea??? i threw my ecu back in the car for good too starts but runs poorly
  4. im gonna go over all my power and grounds tommorow what is the main relay i could try car starts and runs.. just like crap... and wont rev up.. like over fuels
  5. i did get gas at a shady gas station before this happened... i checked the fuel filter and it is clean.. could the pump be clogged??? should i drain the tank and try new gas
  6. why would u think skipped timing belt??? thats the only thing i didnt think about basically the car starts and idles, but when you rev it it overfuels and like bogs than dies
  7. I have a 96 Subaru Legacy wagon. 2.2L 5 speed. Everything was running good on the car till last week when it lost power and broke down. Now the car still starts, but runs poorely. When i give it gas it just boggs and dies. also idles rough never had an issue before with this car soo i finally got the CEL to come on and here are the codes p0105 Manifold Absolute pressure circuit p0201 Injector 1 Control Circuit p0204 Injector 4 Control Circuit p0301 Cylinder 1 misfire p0136 02 Sensor Circuit Malfunction soo i figure with throwing all these codes and after checking out all these parts that it is the ecu. soo i took out the ecu. it looked and smelt fine whatever, i got a new one from a place online now my ecu is 2N 22611 AC930 the ecu that i recieved was a 2D 22611 AB414 I put the ecu in the car and it will not start at all does anyone have any idea why this is doing that??? my car is a 96, This ecu i baught was supposed to work for a 5 speed 2.2l legacy wagon 95-97 please help!!!! thanks - Mark- Ps: I also do not know for a fact its ECU but i figured it could be since it threw soo many codes
