WoodsWagon
5
wrx crash
WoodsWagon replied to crazy D's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Dibs on parts!!! -
I'm picking up another EJ25 tommorow morning, for 25 bucks. The valves on the drivers side were closed so that side should be good. The passengers side may be done, none of the plugs were rusty, so there's hope. The engine was left without a throttle body and injectors, so there was pletny of ways for water to get in, there's even a puddle in the intake. You can't loose for 25 bucks.
They actually weren't a bad idea, it was just that people would figure the auto belt was all they needed and not put on the lap belt, which was seperate. When they crashed, they would "submarine" under the shoulder belt, which sucked for their neck, and they would bury their lower body into the dash. As long as you don't stick your head out the window and then open the door, the belts aren't a problem. There is a pocket at the front edge of the rear seat , down by the floor, that has an allen wrench in it that is for cranking the belts back. Each B-pilar has an acess hole at the bottom for cranking the belts back. If you pull the trim panel off of the b-pillar, you can unplug the belts motor. Then just use the "emergeny" release button and pretend you're hooking up a 2 point harness each time you get in.
I've got 2 apart on my garage floor, a 97 DOHC EJ25 out of an outback, and a SOHC EJ25 out of a forrester. The DOHC has badly rusted and pitted cyl walls, the SOHC had a piston that blew the ringlands off. AND, previously unknown, it has huge gouges in one cyl wall. Like gouges you can feel through the paper towl you're using to wipe down the cyl's with ATF. No big deal I think, I'll use one half of each block and see how it goes. Then I get bit by the thrust bearings, one is on the third main, the other is on the rear main. How many POS EJ25's does it take to build one good one? I've got a sea of EJ22 + EJ25 parts I'll see about collecting another EJ25. There's enough with blown headgaskets kicking around.
Wicked Big Meet!
WoodsWagon replied to Seahag1978's topic in Meet n' Greet. Your USMB Welcome Center
Moosens, if you come, I'll give you those trim panels and the seats to take home with you. -
The shocks are about $50 apice new, so I'd buy them.
I would have gone with a lock-rite front and a welded rear myself, but it looks like it will turn out to be a kickarse rig.
Am I the only one who enjoys busting the front tires loose with the EJ22? Though stock size tires would be rediculous I would think. It would be hard to keep them hooked up at all.
Give it a shot, and take pictures. It's pretty easy swapping them back and forth if you have air tools and a spring compressor. Even with NH rust it's not bad.
Which would make the 2wd shock a cheap way for other people to get a bit of lift.
sonofa****, so I should have bought 2wd shocks. Do you think the parts store will take back the shock I put the spring on? $60 is a lot to swallow for an inch.
OK. That takes the doubt of whether I should have bought 2wd's in stead of 4wd's. I'll run it for a bit like this, the chop them later. I kinda like it high, even though I know it will ride like poo. I've got a cuttoff wheel, so chopping them on-car will be no problem.
If I used 2wd shocks, could you run the accord springs without cutting them? The spring seat is lower on the 2wd's right?
So I put one on a new shock and put it in the back of my loyale wagon. It's gone from being saggy in the rear to cranked way up. From prior experience, it's going even higher when I put the other side together. I'd like some downtravel left on the suspension, so should I cut the springs a bit of leave them as is and hope they settle? The loyale already has a PK 4/4 lift in it and 235/75r15's on it, and it looks like an AA lift now with how far the suspension is cranked.
Ho ho ho, carnage indeed. You see your first picture? On my old 3-door, you had a full view of the ground up to the tipi top of your rust line. You could reach up through the rocker an touch where the metal came toghether for the rear 1/4 windows. THAT ISN"T RUST What I do is start with a blunt flathead screwdriver. Poke the rust on the outside. Poke it till it isn't there anymore, then use a wire wheel around the hole to clean down to bare metal. Weld a patch over it, primer it and paint it. (bondo if your obsessive) For the inside, the easist would be a sandblaster, then some good paint, like POR-15.
