Gender
Male
Location
Traverse city
Interests
Mostly into 1994 and previous Subaru's, like to camp, off-road, go sideways, frisbee golf, wrench and drink beer
Occupation
Engine teardown and prep
Referral
Friend
Biography
A good friend of mine had a 92 loyale in high school for his first car. We put that thing through hell everyday, hill climbing, rallying, catching air, bouncing off trees and such. This was 10 yrs ago .. I am now obsessed
Vehicles
91 turbo Lego, 88 gl wagon, 88 hatch, 97 impreza +
Recent Profile Visitors
subaru4Life2988's Achievements
Member (2/11)
0
Project Ruby Sue 86' Hatch
subaru4Life2988 replied to iceageg's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Love the hatch, I have one as well in Michigan. Not sure how much you care about having a CD player bit a lot of companies are making "mechless" audio players for cars... they don't have a cd drive and if I remember correctly a CD player sits about and inch or so out of the dash to clear the hvac vents. They look much nicer in the dash and most have sd card slot, USB slot and auxiliary plug in so if you really wanted to listen to cds you can run a portable player into the aux. hope this helps -
a little old a little new
subaru4Life2988 replied to joeylives's topic in Meet n' Greet. Your USMB Welcome Center
Interesting combo of cars.... I think the little one was a hatch originally, cool conversion -
First Subaru 1980 1600 GL Wagon
subaru4Life2988 replied to SubieN00bie's topic in Meet n' Greet. Your USMB Welcome Center
A lifetime if properly taken care of -
Hello from Canada
subaru4Life2988 replied to coryl's topic in Meet n' Greet. Your USMB Welcome Center
I've found that most Subarus just push compression into the cooling system with little or no mixing, easiest way to tell is if the coolant overflow is bubbling. Chances are you wont need head gaskets quite yet.. Dealerships just want your money and they will just replace them with the same faulty factory ones. Most of the time they won't machine the heads or even clean them very well. In all fairness it is an EJ25 and it will most definitely need head gaskets at some point. -
Depending on your timeline and such a 2 inch lift is a lot less in depth than a 4 inch, However a 4 inch is the way to go if you have the time. You can stress the axles about 2 inches which can be accomplished with strut/coil spacers. The 4 inch lift you will have to drop the front subframe and rear differential and lengthen the steering shaft. When I did mine I also found I had to space the shift linkage down ( you could trim the body slightly too) as well as the carrier bearing on the driveshaft. I'm sure there are a few more tweaks I'm forgetting about but it's been a while since I've done it.
Hello from Canada
Is the external leak the only problem? Any overheating? The single layer gaskets from the factory aren't the greatest and a bit under torqued. Six star make great MLS (multi layer steel) replacements for the head gaskets. Almost all aftermarket replacement head bolts are junk. You are way better off re-using the old head bolts, I've done many many head gaskets this way with no issues. However if you do replace them use factory or ARP only. I recommend timing belt with new components and water pump at this time along with factory thermostat. Any other questions lmk -
All the michigan people out there, trying to get a plan together for a meet up in northern Michigan within the next few weeks. We had a Subaru parade here a few years back and it was a lot of fun but unfortunately we haven't had something like that in a while ( at least not that I'm aware of). I will update with more info soon. Anyone interested please contact me.
Speedo still doesn't work, it's a problem with the gauge. Went to advance to get my codes ran but the fella who scanned my codes wasn't very helpful and also wouldn't stop talking about how sweet his ranger and alero were..... Please Going to run codes today at the shop today and figure out exact code
