ThosL
6
Everything posted by ThosL
Plug failure within a year caused me unending problems which caused me to change out everything else that I thought could be the cause of sputtering and misfiring. I didn't realize it could be the NGK plugs I put in. Forester is running as well as ever; I put on a couple Cooper tires yesterday that I got from the local junkyard for $50 on the rim each nicely mounted and balanced already.
Outback vs. deer
ThosL replied to 89Ru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
I spoke to him today: I checked it out, it just needs a radiator and condenser and some front trim parts. "my 2013 Impreza with 185,000 miles. Please let me know if you are interested or what next steps we need to do to see if you are interested. I'll probably start calling junkyards tomorrow but I wanted to check with you first. It doesn't hold fluids – – but after checking on the Internet and seeing testimonials – – I was able to drive it home 6 miles by coasting downhill whenever possible. I'll wait to hear from you." 2013 Impreza 185,000 miles. orinal airbags catalytic converter that passed CT Emissions remote start alloy wheels 4 good tires, donut spare clean interior except tear on edge of driver seat. -
Outback vs. deer
I will; he works as a school bus driver so does not have a lot of money to spend on a new car, and as others have said, you can repair the car so it passes all the inspections. If the front end, ie tie rod ends, cv joints etc are not damaged then I'm sure it will be ok. 15 years ago I was hit by another car and after repair it had to go through the inspection upstate. -
My 2.5 with 273K miles has been burning oil, I was told upping the thickness would be good, so have been adding Mobil 1 15w-50, synthetic. Someone said that conventional oil may be preferable on high mileage cars. Another piece of advice was to use Rotella 20w 50. Anyone have an objective analysis on the right oil to use?
Outback vs. deer
A friend had the same problem, thought his Subaru Impreza would not pass CT inspection after replacing radiator and compressor. I offered to buy it from him. -
This driver's side rear strut had broken off due to rust; I had it welded yesterday, could go back to have more done. https://imgur.com/a/safjv8T
I saw this old thread; my left rear is sagging somewhat due to rust. A local guy said he could weld up the strut tower well without removing the strut for $175 for one unit. Is this possible? I saw this Youtube video which shows a rigorous strip down before welding:
Today, I got a couple of the spark plug extenders, will need to drill out the quarter inch orifice before putting it back in. Also due to the oil burn issue, have stepped up the oil to synthetic 10w 40. I've also thought about pulling the catalytic converter and soaking it in acetone or other solvent as the Cataclean is short term, I don't want to get a clogged cat. converter I had around 3 years ago and replaced it then. I could also just pull out the cat. converter and put pipes in there, not sure how involved that is and what you do with the sensors. 2002 2.5 engine 267K miles.
