ThosL
6
Everything posted by ThosL
I changed out the oil and filter today; was being careless about the oil I was using like the Walmart Super Tech 10W 30. Today used Valvoline non synthetic 5W 30 and Fram regular filter. Also changed out the air filter for the first time in 4 years and 80K or so miles. I added a quart of the Lucas high mileage oil treatment product, about $12. I've heard two people in the last week admit blowing their engines by not checking their oil levels. Both were 2015 or so late model cars. One of the guys at Walmart was talking today to his friend about the advantage of the premium Fram filter, that you don't have to change the oil for 10K or so miles. I'm seeing too much of this irresponsible talk about not checking your oil. What type of oil are you using? Do other motor oils have an advantage?
That's what I thought as when replacing one on a 2.2, code went away. I ordered another one will see if it makes any difference. I was thinking I might have damaged the core wiring when I pulled the unit out initially. A mechanic's quick change has turned into a major headache. I changed out the coil yesterday, a ten minute job. The old unit had corrosion dust in the wire plug holes!
Also many of the OE parts on cars from the 1990s, etc. are gathering dust looking for buyers, just check ebay listings for OE parts of various types. I would not buy from the box stores if you can get the same ones elsewhere. On my knock sensor, no performance issue, was throwing the code. How common is it for the codes thrown to be inaccurate?
There are plenty of OEs on ebay, etc. for under $20 delivered. https://www.ebay.com/itm/22060-AA061-New-Front-Knock-Sensor-for-Subaru-Legacy-Forester-Impreza-2-2-2-5L/402339281418?_trkparms=aid%3D1110006%26algo%3DHOMESPLICE.SIM%26ao%3D1%26asc%3D20140131123730%26meid%3D8036857877cb4ae8aee917033980a4d3%26pid%3D100167%26rk%3D3%26rkt%3D15%26sd%3D192926413511%26itm%3D402339281418%26pmt%3D1%26noa%3D1%26pg%3D5411%26algv%3DDefaultOrganic%26brand%3DUnbranded&_trksid=p5411.c100167.m2940 It makes no sense to pay $50 plus as Auto Zone quoted me, plus the unit I got is working at this point.
Solved the issue; one of the terminal wires into the battery broke away and was hard to see, easy fix.
- 1 reply
- 1
Help me decide
ThosL replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
If you have a known quantity, the car is serviceable and runs well, keep it; made the mistake before of getting rid of a Subaru that was mechanically excellent that did not look great. -
I'd point out that a lot of these knock off units are coming from China, may not be quality, not sure. Just check ebay, units are around ten bucks delivered. Went to Auto Zone yesterday to find the code and sure enough knock sensor still. So I checked the connection and made sure the connection was good, car ran better. I disconnected the cables later to reset the code and now the car has zero juice even with jump cables connected. Will start another thread on that.
It was relatively easy on a 2.2 EJ22 due to better access. This one on an EJ25 was a royal pain! #1 access is highly problematic. If the plug on the old unit won't pull apart you will have big problems as the core unit could get damaged. If you get it apart, and then access the bolt with an extended access ratchet, you still have a lot of problems left. So presuming you are able to pull the bolt up, you still have to align the new knock sensor correctly. Then you have to lower the ratchet with extender and bolt correctly through the sensor donut at just the right position through the mounting hole. I used tape to keep the bolt in the ratchet extender, still it fell out and there is no way to reach it with your hands unless you have fingers like a child. All in all an underrated job better left to mechanics. As the do it yourselfer may not have the right tools to do it.
I drove up there this morning and the address was near a bunch of used car and body shops, etc.. I called the guy who had said for me to stop by after 10am, and he said his brother sold it yesterday! No call or email. I told him he was very rude and unethical the way he was running this vehicle for sale, he said "we're Jewish that's how we do business". Unbelievable. Last time I looked at a Subaru in Bridgeport it turned out being one that had been flipped from someone who worked at Sikorski they paid $1200 put some head gasket sealer in and sold for $3000!
I have a friend looking for a reliable car, I have recommended Subarus as low maintenance. I am going to check out this one tomorrow in the low $2Ks, what questions should I ask? 2004 Subaru Forester AWD auto 165k miles runs looks great cold a/c. I'm thinking Subaru is going to be the most reliable for Sam. He has had two cars, a Ford Focus and a VW 4 door fail on him in the last couple years. For low maintenance is this a good way to go?
