ThosL
6
Everything posted by ThosL
My right side front bearing went two years ago. The other side just went out, not safe to drive now. I parked the car on the way to work, in a church lot, called my insurance covered tow company. I had two tows through my Nationwide care insurance; they use a company called "Agero"; This is the second time I used their contact and tow service. The first time two years ago with a vehicle break down on the highway involved a tow to Norwalk and the tow service driver tried to shake me down for an additional substantial amount of money. Yesterday I contacted them at around 4pm for a 730 pm tow. Plenty of time, I received no service and waited a long time and could wait no longer. At 830pm I called them again and was told it would be 90 minutes before the tow company arrived!!! How do I report this company to a state agency? I have never had a similar problem with AAA! Mechanics I contacted can't get to it until the end of the week. What are the minimum in tools if I do it myself? 1997 Legacy Outback Limited. I called around from a front spindle, nothing local available. A parts finder service found one in NH, delays, I can't wait until next week. What risk would I be taking with a pressed in bearing in front? On rears I had a local shop replace the bearings and they failed within 2 years. I replaced them with rear hub assemblys used at a different shop.
Seasonally, when the temperature changes, the heat and A/C will not work until the car is running for 20 minutes. But it has to heat up for the heat to work. Is this a coolant flow issue or wiring with moisture maybe causing this? A friend wants to know. Is 20 minutes too long to get good heat or AC?
I have had the red light on with the Airbag for a long time. No history of deployments with that. The state inspection passed; someone from NY wants to buy the 1996 Brighton, was a little concerned about the light. I think the fuses were checked and don't think I still have a problem one. Thanks for input on this.
CEL codes on EJ22
ThosL replied to ThosL's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
I did the front pads, one side was near metal on metal, the other side was not as bad. I don't know what the likely wear will be on the rear drums once I get the drums off. Thanks for the advice. -
CEL codes on EJ22
A lot of good advice here and I will check out youtube on the brake drum service. What a royal pain, why didn't they switch over all drum brakes to discs when it became economical to do so? Two major hurdles with drums, getting them off and knowing how to remove springs put in new parts and put them back in. Too many challenges unless you are a trained mechanic! With disc brakes, you just take apart the front assembly after jacking the front up and push in the piston with a c clamp and change the pads. -
CEL codes on EJ22
Coil was put in maybe 3 years ago, so seems short term viability. I guess there were drums and discs in same year. -
Hi, on my 1996 Legacy Brighton wagon the CEL codes have come on again. P301,302; P420. The Auto Zone print out said likely a bad coil. I switched out the spark plugs with NGK's today; I changed the fuel filter, as I was thinking maybe the slow starting was due to that. I tried Techtron FI cleaner, again no discernible difference. So I decided to order a coil, some sellers on ebay had OE used, as well as Herko for around $25 each delivered. Is that the right way to go with this? Also as the cat converter code P420 does not correlate with performance and it only comes up occasionally, is there any basic work around on that? Thanks! Another question on rear brake pads; as I hadn't done it on this vehicle, I ordered disc pads as they looked like the right one but once I pulled off the rear wheel it looks like they are drums. Are those hard to get off and do?
Flashing CEL; it hadn't happened in a while. Gas was low but don't think that caused it, there were a couple gallons in the tank I think. I think I've gotten a coolant temp sensor or something before. I have to go to Auto Zone for a code read. The pattern has been periodically trying to accelerate uphill, engine loses power and stalls out with flashing CEL. Goes back to normal after pulling off for a minute.
This hasn't happened in a while; this morning when not letting the 96 2.2 warm up, I pulled out and a mile down the road ascending a hill a loss of power with CEL. I had to pull over for around a minute then it was OK. There has been no CEL code for a while. Any thoughts on sensors that could be to blame? I changed out the MAF sensor a couple years ago.
I had one vehicle where something went bad in the transmission which was due improper maintenance if I remember right; the others have all been fine. Also Lucas tranny oil treatment is good. I've heard varying opinions on changing the transmission fluid and filter that it may stir stuff up that shouldn't be.
