ThosL
6
Everything posted by ThosL
Flashing CEL; it hadn't happened in a while. Gas was low but don't think that caused it, there were a couple gallons in the tank I think. I think I've gotten a coolant temp sensor or something before. I have to go to Auto Zone for a code read. The pattern has been periodically trying to accelerate uphill, engine loses power and stalls out with flashing CEL. Goes back to normal after pulling off for a minute.
This hasn't happened in a while; this morning when not letting the 96 2.2 warm up, I pulled out and a mile down the road ascending a hill a loss of power with CEL. I had to pull over for around a minute then it was OK. There has been no CEL code for a while. Any thoughts on sensors that could be to blame? I changed out the MAF sensor a couple years ago.
I had one vehicle where something went bad in the transmission which was due improper maintenance if I remember right; the others have all been fine. Also Lucas tranny oil treatment is good. I've heard varying opinions on changing the transmission fluid and filter that it may stir stuff up that shouldn't be.
Two fans, they are working. I changed out the thermostat with a Motorad Ultrastat 170 degrees unit. Also Carquest coolant and Blue Devil pour and go which I will probably return. No bubbles in the overflow, but engine seems to be running a little hot, needle of temp is in OK range. Had to burp it out again.
I would trust the experts here, but there remains the possibility of the oil change place messing up. What is their usual step by step procedure? Pull out oil plug, then oil filter replace oil filter after it is drained then plug then refill with oil. If an old filter is still in there then the oil change place probably messed up.
I would scour the online feedback on this shop to see if anyone else had a similar problem; incompetent service rarely happens once, these are lowly paid workers in general. When I went to the local "Splash" car wash that does oil changes years ago, I had a $250 item in the car go missing during the service! I had a police report filed and the two employees who worked on the oil change listed their address as the homeless shelter and the other as the oil change place as their "address". The last person to work on the vehicle is usually the most responsible for what follows. I had an oil pump go bad on a Subaru once and made the mistake of not having it towed immediately.
Thanks for the advice. I have been driving it and watching it like a hawk for any overheating issue. No bubbles coming up in the overflow and I am still trying to bleed it out with the bleed screw on the passenger side. It is still overheating, fan is kicking on, I did nothing with the thermostat, I don't know whether it is Stant (junk) or OE Subaru as needed. Stuck thermostat can wreak havoc. Heat is coming out heater OK. Any other cause for overheating?
Vehicles with problems like this "mechanic specials" are out there in droves; most people would say steer clear of any used vehicles with problems, because something else could be bad in it. Personally if I knew 100% that your analysis was correct and knew how to fix it and could get another 50K plus out of, it would be worth a try at a low price $500-$700 or so.
Ok, thanks for the help and sorry if I got too angry as these problems are very aggravating. I kept trying to do everything to burp it out and finally got the heat back in the heater so it is running well again. Other challenges are things like the lower transmission hose to line without much clearance and the clamp broke and a larger hose clamp did not close out right but I shoved the rubber in well enough so it isn't leaking. I thought I saw some bubbles coming up through overflow but they were small and hopefully not an issue. I ordered the Subaru conditioner.
I've already cycled the car several times, running the car after putting in the new radiator, putting in as much water as it would take with the drain screw open. Still no heat. I tried lifting the car with the tire jack, but it didn't lift it that much. Maybe park the car on a steep hill with the front forward and fill it that way?
Is this really that hard? I changed out a new radiator on an EJ22 today, I opened the bleed screw pouring water into the radiator while it was running. 1996 Brighton wagon, EJ22 engine. I'm pretty sure it did not get cooked in the process of running it around, right. I thought these engines are bulletproof. I had the heater on full blast but no heat was coming out, so heater core was not getting circulated water.
I hope your car is ok, as others mentioned the 2.5 engines were known for head gaskets failing around 150K, but if they were done like mine, you should be ok and Subaru does make a conditioner that helps with small leaks. I would look at youtube videos and see what real mechanics have to say as here. Two years ago I replaced my radiator, the head gaskets had been done at 150-175K I believe. As it was failing there were minor overheating issues. It runs fine now, no CEL. Also the bleed screws on the top of radiator, can strip out so you have to be careful.
I had the same problem with a 99 Outback that had a 2.2 put in; got a lot of miles though the weight of the car was designed for a 2.5, much stronger engine. I was out in Middletown NY coming back to CT and that center hose went and there are others under there. Probably only seasoned Subaru mechanics know what to look for and if you don't tow it, engine can blow. I tried some Alumiseal, and waiting for the pressure to come back up with the cap off pouring water in and the pressure release loose, when the pressure came back up there was like a line of leaks on the radiator, probably the plastic.
