ThosL
6
Everything posted by ThosL
Actually addressed all the CEL issues; changed out wires, did the body work, burped the coolant system that finally fixed a nagging problem, it would heat up then sometimes accelerating up hill would suddenly have a spaz attack. Not any more with the coolant system burped. Only real issues I can see is that the tires will need to be changed out in 5-10K and the rear wiper. https://newyork.craigslist.org/fct/cto/d/new-canaan-1996-subaru-legacy-brighton/6955343208.html
Unfortunately this is status conscious Fairfield County, CT where people want status cars...A functional econobox is much better than the popular Jeeps, etc. but harder to sell. The Au Paire girl who came to check it out was focused on the brakes, maybe not enough "grab" for her but pads are cheap and easy to install as I explained.
An older sister who went into assisted living a few months ago necessitates our selling a 1996 Subaru Wagon. I got several codes at Auto Zone: misfires on two cylinders, 301/302; Catalyst system issue, P420; also P115 Coolant circuit. I'm getting a little red light on the air bag, not sure if that indicates a faulty unit. I pulled the battery cables, so the CEL, etc. didn't come on. I used the guaranteed to pass gas product and changed out the spark plug wires. I drove around 40 miles before the test at emissions, and the guy passed it though the sensors were not all "ready". What is it worth at 200K, good body, though; fixed a couple rust spots today. No real issues except rear window wiper doesn't work?? My brother did body filler on rust holes in back.
Wrong diagnosis
ThosL replied to ThosL's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
I work at a big box retailer with 100K plus products, today got some yet again with generators that won't start; I had to educate them on the dangers of alcohol in gas, I wonder how many of our Subaru problems are due to problem fuel? Running the car down to one gallon left or so? Remedies? -
Wrong diagnosis
OK, not sure why the mechanic said he checked with the parts store and a new pump was $200 so he went with used. It looks like Advance has them for a lot less as their usual retail which you can get online discounts on: https://shop.advanceautoparts.com/c3/fuel-pump/15378?krypto=16ltsxXemOT95rflFF%2BrHWRYPSnT3x7uNZhTovA0LHvnnDsP98J5XOYlD1ZHqu8T7KUmuMp2NORkO58ms44gD8pzXB866lju8jVE1caVii9W2Y7TGID0EpCfo8ntzou4ybhIkrNqVnvrikZfFg%2BGbfT6TzZpdtMqor1o2uF2b2SwH3EleqoWJ1sqNaNIz%2Fq5KzeOJHDmM826GzNE%2FQMdG5YkLFQqBt95xDSnzLcpWLcN0gJalYK9Rim6ZfyVPSqsQycWRTxjcgkLQMqyrErdy%2Bz6IgXTrHaDsgYgkd0s642BMHkyICWoYuNyatXf1l2BMGLBwEJ2rrzoICbDdFXtUQ%3D%3D -
Wrong diagnosis
$225 was fair for a 97 2.5; quick turn around time; I don't know any shop around here who would have done it for under $300 and most don't put in used units, so not sure why experts are critical here on price when they said that valve cover, cam cover gasket replacement, etc. would be a lot more than the same mechanic did for $300 plus parts and threw in welding on exhaust and changing out a couple coolant system hoses. -
My Subaru started up in a grocery parking lot yesterday as I was driving toward the main road I lost power fairly quickly. I figured the timing belt broke. I was hoping low RPMs meant the engine wasn't damaged as can happen. I had it towed to my mechanic who got to it today. Different verdict; the fuel pump had died. Fast efficient replacement with a used unit, $225. What would be the tell-tale difference between the two failures, timing belt vs. fuel pump?
I would only go to dealerships for recalls or other service covered, because their prices are very high retail, they're greedy and take advantage of customers as others have said. Subarus are not that complicated, there are many mechanic shops around here and probably most geographic zones, even in the South.
The dip stick may be off; when I have checked it, it barely registers. Adding a quart and it soars up. There is a limit what do it yourselfers can do. The clearances are so small with the 2.5 units, I don't see how I could change out the gaskets. Does mixing oil cause problems? 10-30 with 20-50 with HD30, etc.. At a lot of the oil supply places there is not a good range of supply of motor oil.
I checked with Town Fair periodically and they have a 30 day trial on new tires. I got a set of 4 Toyo tires which were almost new, they had a Maine warehouse ship them down; $50 each and I had a local tire place mount and balance them for $15 each. My guess is that other tire places have trials like this then they need to sell the tires. No guarantee though.
I have a 97 2.5 Outback that has had a slow leak in the valve cover gasket. However I just checked it and the stick was barely showing much oil after adding 3 quarts. Lhe oil warning light had gone on the dash. Aside from the involved job of changing the gaskets is there any stop gap measure? Lucas oil leak product?
