ThosL
6
Everything posted by ThosL
I've been noticing low pressure on my cooling system; within a short period of turning the car off I can take the radiator cap off with no spurt or pressured water coming out. Not sure if this is good or bad. Head gasket must have been done as the engine runs very well. 1997 2.5 limited Outback. Also, sister's 1996 2.2 recently had an overheating episode, car usually runs very well with problem of occasional loss of power soon after starting up as mentioned earlier. Stuck thermostat is my guess.
Do even the OE radiators from Subaru eventually leak? My 97 Outback is leaking periodically on the side as the lower drain cock. A part-time mechanic looked at it and said that the radiator will probably need to be replaced or he recommended a stop leak product. I don't know if the Subaru stop leak product would help. Thanks.
There are a lot of tricks mainly short term; pulling the thermostat out so the water courses through the system very quickly; putting the heater on to suck heat out of the system. Make sure the fans are working properly. I'm surprised that excellent high tech remedies haven't developed with the expensive head gasket expenses.
- 20 replies
- H6
- head gasket
(and 1 more)
Tagged with:
It depends on how bad the leak is. You can pull the thermostat which will take pressure off and buy you time; also Blue Devil guarantees are good as gold, got my money back 4X! Fiberlock is not bad either, I think it was double your money back. Just make sure a coolant flush product is on the receipt and follow directions to a T. I've driven for many months on blown head gaskets.
- 20 replies
- H6
- head gasket
(and 1 more)
Tagged with:
I'd have him ask at Advance Auto, Auto Zone or Napa; they should be able to do the computer code for free and with all the Subarus there I'm sure there are good local shops probably on the outskirts of the city. I did business with a couple shops in Craftsbury and near St. Johnsbury as well as around Brattleboro.
Was at Monro earlier for a brake job at under $25, it makes sense plus they checked the brakes out. 97 Outback was making some rear metal noises, they checked it out and said it was bad rear brakes showing me the rear cylinders, trying to say they were metal on metal, which they weren't, and one of the calipers was no good. Estimate = $350. So I checked out this video on youtube: It made it look easy, only rotors can be a bear to get out without power tools or beefier ones than I have..... So I picked up the pads at Advance Auto for around $15 with the discounts and didn't have any real problems, got the brake tool kit for the piston at Auto Zone as a rental. A pretty easy job considering drums can be rougher. One of the caliper pistons was a little rusty, not sure if that becomes a problem down the road. I didn't see a tear in the rubber, not sure if that would be a huge issue if it was compromised.
