![](https://www.ultimatesubaru.org/forum/uploads/set_resources_9/84c1e40ea0e759e3f1505eb1788ddf3c_pattern.png)
ThosL
6
Everything posted by ThosL
If you want to play hard ball with their intransigence, you could contact the state AG filing a complaint with them. Plus lemon laws are pretty tough for used car dealers to fight. Go online and post an anonymous or a review in your name depending on whether they may retaliate. If you are a member of Angie's list they probably field reviews there. Lots of ways to fight back.
I spent about an hour on the main long coolant line between the airbox and the engine; both are hard to get to, one is much longer, the one with the original problem. I tried a couple of those finger tightening clamps to prevent the slight leak. They just made it worse. What would be a reasonable amount of mechanic time on replacing the two hoses, a half hour? Why are these two quarter inch or greater lines so hard to get to?
To each their own and I doubt that quality mechanics would lose customers if they had posters around, as people just want quality work at reasonable prices. I remember seeing a poster of Shania Twain up in Monson Maine at Kent Bishop's garage 10 years ago. So I asked him who she was and he said she was a beautiful woman which she is.
Drain hose
ThosL replied to ThosL's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Most likely, had the defrost on to suck excess heat out. -
I was looking through this forum for a match on this topic, I didn't see anything that jumped out answering my question. There is a drain hose I have seen water coming out of near the back of the engine out a drain hose. I was wondering whether the heater has one of those or just the A/C? I virtually never have the AC on, the water was draining in a small way from the drain hose when the AC was not on.
I've never seen this discussed, but seems a universal trait of mechanics and garages to have various versions of pin-up models around the garage; from the Sports Illustrated versions to more racy types. Is this pretty universal at shops or do they have certain standards at shops where customers may be turned off? Like at one Subaru yard I asked to use the bathroom and their was a pile of "Swank" or similar mags. around.
Fuel mileage
ThosL replied to Wolfman01's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Probably in ideal circumstances you can get excellent mileage especially with those superlative newer models. The winter with the fuel mixes and oxigenation it is always worse. I'm getting around 25 mpg even with a bad head gasket apparently. Also speeds affect mileage, or used to; the higher the speed the worse the mpg -
just a strory
ThosL replied to fredinct's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
What is a reasonable charge for one rear wheel bearing? I'm hearing tell tale noises on one side.
