Tahoe Subaru
Everything posted by Tahoe Subaru
I can't work on the car where it is. It needs to be towed to my house. The axles seem tight but I will fully inspect them. The noise seems to come from the front diff. I only moved the car 10 feet. that was enough. With the open diff. we were able to spin 1 wheel on the ice slowly without moving the car and my head 1 foot from the transmission. Horrible grinding. slipping, binding, bucking.
My friend has an 85 Xt. I think the front diff. is shot. Has grinding noise from diff. area. also the axles lock up. Still moves but bucks and grinds and slips at very slow speed on ice covered road. sounds like ring and pinion mesh problem. anyone have experience changing or repair the front differential? anyone know what years and models may interchange? there is an 87 xt at the wrecking yard. Haven't seen it. any advice on cost and time to replace, He is broke like most of us. Thanks
There is a dot 180 from the key. Put the dot at 12 o'clock. If you have a manual transmission there is a retainer you need to remove to see the line in back. It lines up with a line on the block. Also there are two bolt holes in the gear. they should be at 3 and 9 o'clock. there is also a triangle mark don't use that. remember the crank goes two revolutions to the cams one revolution. the timing can be tricky for the first timer. but. It has to be dead on. or else. http://uncyclopedia.wikia.com/wiki/Or_Else
Subaru's are famous for HG problems. Sometimes they overheat for the normal reasons. leaks. The last 3 cars brought to me for HG's, 2 were water pumps, seems like no one changes them at the first timing belt change. One was a hose at the throttle body. All were overheating which can cause the head gaskets to blow. Just food for thought.
the chart floating on the net is wrong. I have your same car and have changed transmissions. it is a 4.11 ratio. look on opposed forces under train to get the ratio. Also you can jack up 1 rear wheel spin it 1 revolution and count how many times the driveshaft turns. It will be half the 4.11 or just over 2 turns. If it has the 3.9 ratio it will turn just under 2 turns. remember to use a jack stand for safety. that trans number is on the driver side, near top, front of transmission. that number is the same on mine. I replaced with a TY754VCACA
on a 5 speed there is only one fill hole, dipstick. the diff is part of the transmission. transaxle. It takes gear oil. Look in your owners manual. As far as the transmission it has 4.11 final drive. So you need to match that for plug and play. Looks like outback is your best bet. but a gt may have the same 4.11 ratio. http://www.car-part.com/ http://opposedforces.com/parts/legacy/us_b12/type_20/
the 99 is the cross over year. 8 bolt block. early years had 4 bolts. if yours has 8 mounting bolts or (4 studs and 4 bolts) engine to transmission. then the starter wont mount to an earlier block. you can do it but you need to thread the transmission at the lower starter mounting bolt hole. Its a pain with the transmission in the car but doable. I would keep your engine and rebuild the heads.
Ericem you win the prize Update.. I have the car running. 98,000 miles, 25 miles after Subaru inspected the belt. failed timing belt tensioner, 6 bent valves. leaking head gasket, had subaru conditioner installed in 2004. compression test after hanging a new belt. 0-0-180-120 the 120 cylinder had 2 bent intake valves, the 0's had bent exhausts, the car actually ran on 1 and a half cylinder. but not very well Subaru engine gasket set. Complete timing kit and water pump New Clutch and flywheel New tires Left front wheel bearing Right front inner axle boot
