sea#3
Location
Vancouver Canada
sea#3's Achievements
Subaru Fanatic! (6/11)
12
The dealer said the head gasket was leaking and wanted the radiator sent out to get flushed and replace the gasket for $2000. I would send the rad out first and flushed then give it a try for the overheat , You may not be getting enough flow through the rad causing the 3/4 temp reading . The SOHC head gasket don't usually cause the overheat situation like the DOHC head gaskets do . I'm assuming that the dealer is saying that you have an external coolant leak and not a blown head gasket SEA#3
You won't bend valves just turning the cams with the engine off. I have built 30+ EJ dohc engines, trust me you can spin them 360 degrees. Then you've been lucky , there is a caution in the manual as to which way to rotate the cam gear for alignment so that valve damage does not occur It is mentioned in the article below http://endwrench.com/images/pdfs/2.5Timing.pdf SEA#3
P0519 questions
sea#3 replied to yohy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
yohy ,,I should have been more clear .. yes you should still go through the flow chart and if everything checks out ok then i would suspect the neutral switch on the side of the trany . If you can find a scan tool that will give you live data on the switch you can put the transmission in gear and watch the on/ off signal while you gentle move the shifter in gear . If not you could try hooking up to the switch with an analog ohm meter and watch the needle for fluctuations while gently moving the shifter in gear . There should be continuity when in gear , open in neutral SEA#3 -
P0519 questions
Asuming it is a manual trany , you would need to replace the neutral switch on the side of the transmission , What is hapening is the ECM doesn't know if you are in gear or not , so if you down shift and the revs go up it thinks the IAC is not doing it's job of adjusting the idle and sets the code It probably won't be covered under the drive train warranty but it 's not that expensive to fix SEA#3 -
Hybrid Sube???
sea#3 replied to JEGIII's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
