sea#3
Everything posted by sea#3
If you have a sunroof leak ,your more than likley going to have to pull the sunroof mechanism out and resal it But before you do that you can check the drains first by taking a 1 gal size jug full of water , opening your sun roof all the way and pouring the water by the corner of each side at the front of the sun roof ,slowly it will fil up fast ,also make sure your on the out side of the sunroof guide /rail The water should come out just behind the front wheels and the rear of the rear wheels . The tubes for the drain run down the front "A" pillars (front) and down the "D" pillars (rear) The exit through each wheel arch just under the inner fender liner The gasket you are looking for is actually a Butyl sealer (black) simalar to what they use to seal windsheilds with. The sealer is just under the guide/rail and the frame that mounts to the body What happens is the sealer dries out and cracks and lets the water from the outside of the guide/rail into the inner part of the sunroof on to the sun shade and down the back of your neck when you hit the brakes or round a corner hope this helps SEA#3
Ok here is a possible answer to all your problems There is a main relay located just above in a hell and gone location just above the interior fuse box . Brown relay with a brown connector ( says JIDTCO on it and a part # ) If you pull the knee pad off you can just see it on the far left way at the back What is happening is the contacts in the relay go bad and cause resistance in the circuit that cause a voltage drop to the computer , which can not compensate for the drop What usually happen is what you descibe , loss of power, check engine light on (not always) , pull off to the side of the road ,shut engine off restart and runs fine for either a short time or for months before it happens again The relay is cheep( approx 25$) compared to changing MAF For the price and maybe some skinned knuckles ( and may be a lot of swearing) Give it a try I have fixed 3 cars this way SEA#3
Legacy 2.5 I just went to the photo gallery site and saw your ride ( very nice) I noticed the mags and had a thought . I have come across where the mag doesn't seat properly to the mounting surface of the hub and cause a creeking /binding noise just wondering if you still have the stockers ,throw them on and see Diagnosing a noise at the best of time when you have the car can be frustrating Hope your level of frustration isn't elevated by all these sugestion SEA#3
From what you desrcibe ( and i have come across this before ) if there is a slight run out on the rotor or the hub and pads push back and forth in the caliper holder .You won't necesarily get any brake vibration at higher speed . Maybe check the run out . What type of lube did you use on the pins and the retainer clips ? I pefer using Sil-glyde. Also did you lube the contact points where the pads contact the retaier clips ? Did you orient the guide pins correctly Top one - solid Bottom one - Black nylon bushing on the end From your description it sounds like it in the brakes
Mikeintenn Your drop resistor has popped the breaker that is inside your drop resistor ( it has desoldered it's self) It is located in the heater housing behind the glove box ( white 4 terminal connector) pull it out and carefully pry between the white plastic peice that the connector plugs into and the partical board that is attached to the square cage . Once you have the white plastic peice off , straighten out the tabs that are bent over , pry the partical board off the cage . The resistor will come with the partical board , there should be a peice of solder floating around in the cage . You should see a loop on the resistor that is the breaker it should be lifted off of where it should be soldered. Just solder it back on NOTE: if it pops again you may have a problem with you blower motor drawing to much current SEA#3
starter problem
sea#3 replied to Subie's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
You don't say whether it's an automatic or standard I suspect you have a starter that is for the opposite of the type of tranny you have SEA#3 -
You can try and do the flush trick , but if that doesn't work you probably have some silicone sealant stuck in one of the rocker shaft oil delivery holes 1) detremine which side it is and which rocker Then pull the rocker shaft assemble off . If it's the left bank making noise (drivers) take off the front tower pedestal from the shaft, if it's the right side (passenger)take off the rear tower pedestal.Look at the metering oil hole on the shaft there is usually a piece of silicone stuck in the hole 2).If not there go to the affected rocker , see if there is any oil present coming out of the hole at the end of the rocker when you push down on the valve lash adjuster ( which should be soft and spongy) You can also "gently" pull the valve lash adjuster out of the rocker with some pliers and clean out the passage in the rocker 3) reassemble every thing and start engine and keep it at aprox 2000 rpm NOTE : It may take 10-20 minutes to bleed the air out of the valve lash adjuster , some times running for 5-10 minutes then shutting the engine off let it sit 5 minutes and restarting it purges the air faster hope that helps SEA#3
Shifting woes!
sea#3 replied to radams's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
There is a TSB on endwrench.com that should rectify your problem (i think someone else has suggested this ) It involves replacing the slave cylinder and the the hose that attaches to the slave cylinder SEA#3 -
pinecone45 First what is the producion date on your car , you can find it on the B-pillar ,drivers side at the bottom of the door jam If it was built between Feb /1999 and Jun 2000 there is a difference between AT and MT engines on the cam sprocket AT # 13019AA09B Cam sprocket MT # 13019AA10B Cam sprocket There is also a difference on the crank sprocket as well AT # 13021AA16A Crank sprocket MT # 13021AA17A Crank sprocket As far as the engine you have in there now and when it was built is another story What i would suggest is you take your VIN # in to your dealer and they can tell you if these are valid for your original engine( because there is overlap from Feb 2000 on where the cam gear does go to #13019AA09B for both AT and MT) SEA#3
Ratpeters THAWA is correct the tube that is leaking is #11 on the site below It means your going to have to pull the trany and pull the Torque Converter Case off and repace the tube and some seals SEA#3 [email=http://www.ultimatesubaru.org/forum/attachment.php?attachmentid=1445]http://www.ultimatesubaru.org/forum/attachment.php?attachmentid=1445[/email]
pinecone45 The A/T engine do use a different cam gear than a M/T engine Also the crank gears (reluctor) is also different between engines This is where you may be having some conflict with erroneous codes and the NO START situation What I suggest is that you put everything back that was originally from the original motor (cam gear, crank gear. Intake manifold and engine wiring harness) SEA#3
therealciviczc Look on AVK's attacment #8 is the clip that holds that tube to the torque converter , make sure that is secure . It should lock into position .The tube drives the oil pump . # 10 is a square cut seal make sure it has not folded over or is pinched (which is highly possible ) Also make sure the input shaft #20 is all the way in When you get everything together the torque converter should almost touch the bell housing ( which i'm sure you already know) it should sit approx 3-5mm away from the bell housing SEA#3
