Legacy777
You say you replaced the compressor. Did you drain the old oil out and refill it with PAG or Ester oil? The manual states that you drain the oil from the old compressor in to a container, measure the amount of oil. Drain the replacement compressor and add new oil (Pag or Ester oil) in the amount that came out of the old compressor. Also did you replace the receiver/dryer? It looks as if there may be to much oil and /or water in the system (It should be clear R-12 or R134a)
The only way to get the water out of the system is to change the receiver/dryer
And vacuum the system for at least 45 min to an hour
The pressures look about normal for the low side but the high side may be a bit high, but that’s hard to say without knowing the ambient temperature and humidity
Sea#3
