About Logan K
- Birthday 06/22/1992
Gender
Male
Location
Edmonds
Interests
Subaru, hiking
Occupation
Service Writer
Vehicles
91 Loyale 02 WRX 91 F150 87 GL WAGON FWD
Recent Profile Visitors
Logan K's Achievements
USMB is life! (4/11)
18
Unable to shift after replacing reverse light switch
Logan K replied to Logan K's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Turns out the switch was actually the wrong one, just a little too long. Got another one from Napa and fixed the problem. -
Yesterday morning, I installed a replacement reverse light switch from Napa. The car is a 1991 Subaru Loyale, with a 5 speed dual range swapped in. I drove about 15 miles, got to the store to get some supplies and all the trans would only shift into 5th gear! No 1-4 and reverse. Backed the switch out about 5 turns and my shifting returned. I do not see anything mechanically wrong with the switch, or different from the OEM one I removed from the transmission. Has anyone else run into this issue?
Using Carb longblock in SPFI Car (ea82)
I am using SPFI however...so will that throw off the fuel/air mixture if the EGR is disconnected -
Any harm if I just block off the EGR? I dont really have the tooling to make a pipe. -
Logan K posted a topic in Old Gen.: 80's GL/DL/XT/Loyales...
Hey there, so I am replacing the longblock on my 91 loyale with an engine out of an earlier carbureted car. I will be swapping intake manifolds and exhaust over, is there any other things i need to do to get this vehicle to run properly? From my understanding it should be pretty straightforward, but I am planning on getting this done over the holiday weekend and would rather gather my parts together now. Any feedback would be appreciated. Thank you! -
Can't keep replacing axles
Logan K replied to XHighOctanex's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Working in the automotive repair industry, I can say with some certainty that a BIG problem with some of the aftermarket CV axles is a lack of grease. Several of the failed units we have had come back for warranty replacement have been found to have little to no grease in the joints. There are several outfits that will rebuild your axle here in the USA...somewhat more expensive but the quality control is much higher. -
starter momentarily stops/hesitates - then starts
Logan K replied to idosubaru's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Check draw from starter, load test battery? I think my XT6 did the same thing, i put a new starter in mine and fixed it. -
2002 WRX, i have an intake leak coming from the shaft that actuates the TPS on the side of the throttle body (Confirmed with smoke test). Has anyone had this problem before, and if so were you able to fix the throttle body without replacing it? New from the dealer is $600, and the aftermarket units look like they dont have a provision for cruise control. Any advice would greatly be appreciated! Thank you!
