Logan K
Everything posted by Logan K
  1. Turns out the switch was actually the wrong one, just a little too long. Got another one from Napa and fixed the problem.
  2. Yesterday morning, I installed a replacement reverse light switch from Napa. The car is a 1991 Subaru Loyale, with a 5 speed dual range swapped in. I drove about 15 miles, got to the store to get some supplies and all the trans would only shift into 5th gear! No 1-4 and reverse. Backed the switch out about 5 turns and my shifting returned. I do not see anything mechanically wrong with the switch, or different from the OEM one I removed from the transmission. Has anyone else run into this issue?
  3. I am using SPFI however...so will that throw off the fuel/air mixture if the EGR is disconnected
  4. Any harm if I just block off the EGR? I dont really have the tooling to make a pipe.
  5. Hey there, so I am replacing the longblock on my 91 loyale with an engine out of an earlier carbureted car. I will be swapping intake manifolds and exhaust over, is there any other things i need to do to get this vehicle to run properly? From my understanding it should be pretty straightforward, but I am planning on getting this done over the holiday weekend and would rather gather my parts together now. Any feedback would be appreciated. Thank you!
  6. Working in the automotive repair industry, I can say with some certainty that a BIG problem with some of the aftermarket CV axles is a lack of grease. Several of the failed units we have had come back for warranty replacement have been found to have little to no grease in the joints. There are several outfits that will rebuild your axle here in the USA...somewhat more expensive but the quality control is much higher.
  7. IT HAS a major leak from the throttle shaft at the tps side. No question about it. I know this is the problem, I was looking to see if anyone else had encountered it before and had a cheaper fix. Thank you for your help =)
  8. Maybe find a local machine shop and see if they can get a rebuild kit for you? If one exists, they would likely have access to it.
  9. Check draw from starter, load test battery? I think my XT6 did the same thing, i put a new starter in mine and fixed it.
  10. Rough idle, fluctuating boost gauge, lousy fuel mileage. And no, not too normal but at 200k miles anything is possible right? I have seen similar problems before on fords and nissans.
  11. 2002 WRX, i have an intake leak coming from the shaft that actuates the TPS on the side of the throttle body (Confirmed with smoke test). Has anyone had this problem before, and if so were you able to fix the throttle body without replacing it? New from the dealer is $600, and the aftermarket units look like they dont have a provision for cruise control. Any advice would greatly be appreciated! Thank you!
  12. are you looking on the super-pro website? the larger diameter bushings they offer are for the ea81 stuff
  13. Interesting...if all else fails i may put power to the motors, get my belts to go to the locked position and then unplug that module. Did that fuse affect your power windows at all?
  14. Hit a big puddle offroad yesterday and now my power windows, power seatbelts and turn signals are all inoperable. The lights will still flash when i press the hazard button. I did not check this fuse however, as my horn and clock still work...has anyone had this problem before? I was almost wondering if my ignition switch might be an issue as the components that no longer work all run off key on power.
  15. Get a late 90's outback or forester steering shaft it will work no cutting and welding required
  16. That fan should come on before boiling temp. I would replace the sender/switch that goes into the radiator, those are pretty cheap.
  17. There was a fella from the Neatherlands (I think) on here a few years back that had a ea81 car that I do believe had a FACTORY lsd. Or at least one with a tag that looked different then the ea82 stuff im used to seeing. He was completely restoring the car, adding propane...he had a bunch of pictures.
  18. Because they are no longer available new, and who knows how worn a used spring is going to be.
  19. TB299300K1 Is the part number for the Continental belt, tensioners and idler kit. It can be alot cheaper to buy the parts and pieces individually then as a kit however...
  20. Head gasket set Part Number HS9392PT2 for fel-pro. Can be purchased online. You will also need front and rear crank seals, oil pump gasket set and oil pan gasket. I would recommend shopping on RockAuto.com. In the vendor section of this forum there is a code posted for a 5% discount on any purchases made there.
