beat_truck
Everything posted by beat_truck
  1. Hi, is it an auto or standard? The autos, 3 speed especially are harder on gas.
  2. Thanks Turbone, you're right because I just found this in a FSM that I found searching online. Thanks, Josh
  3. No, the fluid looks really good. The trans works perfect otherwise. Where is the actuator? There is only one vac line that I see and I think it is for the modulator as it goes to the motor and has vacuum all the time.
  4. Hi, as in the title, the 4wd on my wagon doesn't work. Does anone know which solenoid or actuator shifts it into 4wd? Whan you push the button, the light for the 4wd comes on but nothing else happens. Even in wet grass with a light push of the gas the only the front tires spin. I doubt anything in the trans is actually broken as the car was owned by an older gentleman and is in excellent shape and was garage kept for most of it's life. Any info will be greatly appreciated. Thanks, Josh
