WJM
About WJM
- Birthday 04/05/1984
Recent Profile Visitors
WJM's Achievements
Elite Master of the Subaru (11/11)
14
I would use your stock injectors. I've never drilled the EGR, so I dont know what to tell you on that one. If you didnt have to deal with emissions inspections, I would remove the EGR system so you wouldnt have to deal with it.
Get a METRIC feeler gauge. Dont get the one with SAE measurements on it. They are only $5 or so from any Snap On/Matco/Mac/Sears/whatever. 0.20mm intake clearance 0.25mm exhaust clearance Despite what the manuals will say, ZERO tolerance on the valve clearance. Make sure you get them to those values. The engine will run SOOOOOOOOO much better. Even if they are "close" and "in spec" according to the tolerance that the manuals have, it is EXTREMELY noticeable when you have them dead on vs "in spec" but not dead on the spec.
The cam is going to get sticky/stop moving when the lobe starts to make the lifter climb up the lobe. As long as it moves freely when the lobes are not trying to lift a valve, its all good. Use only SUBARU 11044AA610 gaskets. Do not use any aftermarket gaskets. Every one that I've seen and seen used leak/blow internally just like the older SUBARU gaskets pre-11044AA610. For the EJ/EG/EA engines with the "composite" type headgasket, EXCLUDING the 1996MY EJ25D, it is 'ok' to use something aftermarket since subaru does not offer a MLM gasket as a replacement. I have seen those used with great success.
if the cams spin very freely/like butter in the heads, re-use. If there is scoring, moderate to heavy, and they still spin freely, its a toss up. In most cases in they are toast, they will not spin freely and there will be heavy scoring. DO NOT RE-USE.
You should probably replace the headgaskets since you are not going to be far from them. Along with the timing belt.
I read this wrong. I thought it read: XT front clip on an RX. AkA front of the car is an XT and from behind the fenders and back, its an RX. Woops.
EJ20H swapped Gen3 Brat build Continues Tear down time.
WJM replied to subaruguru's topic in Subaru Retrofitting
WHAT A PROJECT. I sure wish I could take that xt6 off yer hands for some PARTS completness for my XTDL. -
_*I*_ had that idea back in 2004. No one liked it. I LIKE IT. I'll do it eventually. CNAT BET O HARSD. excuse me with the bailey snad crow on the cold rockz.
What upsets me the most is that the tires that come on them are actually GOOD tires and I have no complaints other than the fact that SOA bid too low and thats what they got: the lowest bidder supply of tires. A fine tire it is, it just vibrates at anything less than ~40psi in it. When they scrapped the 12 or so tires we replaced under warranty, I got them and I mounted/balanced and run 44psi in them. Smooth as butter on 96 Legacy Outback (barely fits) and 05 Baja Turbo.
