Newb
Glad to see you are enjoying the little beast! I had fun building her, welcome to the forum.
- UEL single port headers (updated post)
Age Old Question
I have both my 80 wagon and my 98 impreza, the 80 does most of my town driving and fishing trips up in the mountains the impreza is for long trips and really hot days (ac is nice sometimes) I did do the ej swap to the 80 because it is nice to be able to get her moving when i need to and I tow my camping trailer with it. Just need to get the camber issue fixed since its lifted 4" it can be kinda tricky on wet roads on cornners. But I guess having a taste on both world is fun. The old subset do great on the wheeling trails as long as I stay out of the huge hole the big Chevys make haha since I don't really like flooding the inside of the car wich has happened to me a few times. Personally i feel it's a shame to crush the old sues unless it has been wrecked so bad that it's done for. I have crushed a few of them but not before taking damn near every usable part off of them to feed my old beast haha. I say keep your old sure and if you have to have the new one just have two lol. If I had a lot of property I would probably have quite a few since they are so cheap but who knows how much longer the old gens will be around.
Just added an LSD rear diff in my EJ'ed 80 wagon should help her out on the trails! Now I just need to get around to painting the car and adding some 15" wheels so I can run some real mud tires.
This is a Subaru?
NWSubie replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNot trying to thread jack but my dad has his 92 svx for sale. Its in good shape but does need some tlc from someone with more time than we have. It runs and drives but will stall out sometimes when shifting from park to drive. Wont die if you just tap the gas slightly when shifting. I took it for about an hour drive last night and it drove fine. PM me if anyones interested. Its had its trans rebuilt and a swaped jdm engine with paper work showing what was done. Its located near St. Helens OR.
New Stant "Xactstat" OEM thermostat available at parts stores!
NWSubie replied to GeneralDisorder's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe T-stat on the left is the one Napa gave me when I did my EJ swap in my 80 wagon. The car took forever to heat up and often would not clear all the moisture off the windows. The new Stant one I installed looks a lot different and I actually thought I had ordered the wrong one due to the size difference but nope it installed as it should and works great so far. Car heats up quicker although I have not driven it long enough to see if I can actually defog all of the windows yet. Thanks GD for making this link thats how I heard about this great non-oem option. :cool:
Nice to have my impreza back!
So here's props to GeneralDisorder and the guys at SSI (Superior Soobie and Imports) in Milwaukie OR. I contacted GD aka Rick about a noise/vibration that developed in my 98 OBS it ended up being a bearing in the imput shaft inside the trans not something I personally wanted to attempt to fix. But thanks to SSI I got my trans back two days later and now it shifts like new! It was suggested that I use extra s trans fluid in it and I can really tell a difference it's never shifted so smooth. So just wanted to say thanks to GD and to let you all know that there's a good Soobie shop located in the Portland area so check em out.
Recommended Maint. W/ Clutch Job
NWSubie replied to GrnBtlWgn's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou may want to make sure the clutch fork is in good shape when you do the clutch I had mine wear through and it snapped on me. Not very common from what I hear but hey it happened to me. The fork just pops off its just held on by a clip. Also use new clips for the throw out bearing they are cheap at the dealer. Its pretty easy to do the clutch on these cars though. I personaly like using exedy clutch kits.
SVX stalls and dies when engaging reverse
NWSubie replied to NWSubie's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHmm maybe I'll play around with it a bit and see what happens.
NWSubie replied to NWSubie's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell I set it to .5v with the engine off if I did my research right that's where it should be. But after the engine starts it drops to .38v and levels off at .42v is it normal for it to be that low. I understand that the sensor is essentially a spring that tightens up as the throttle moves changing its resistance. Also I read that the ohms on the sensor should be 5k between the red and black wire mines at 5.39k. Maybe this sensor is no good?
NWSubie replied to NWSubie's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIs that hard to do? I see that It has two screws I'm assuming I loosen them to adjust it.
92 SVX recently started stalling when sitting idling in "park" it will shut off as if the key was turned off. If I give it some gas while shifting it will engage and not shut off. It will do this if I shift from "park" to "drive" as well. but its fine if I shift to "Neutral" Any Ideas on what I should look at? I removed and cleaned the IAC valve today with MAF cleaner but still has the same problem. Once the car is in gear it runs and drives fine its just the initial selecting drive it seems to have an issue with.
Thinking about a DIY vinyl roof overlay
NWSubie replied to NWSubie's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWow thanks for the info I finally got to wifi so I could watch the video and that is pretty impressive stuff im surprised it can hold up on car wheels. Guess once my shop bay opens up I can try it out.
NWSubie replied to NWSubie's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIll definetley look into the 3m stuff I dont know if ill be able to get it on the hood scoops but its worth a try. Can it be heated slighly to be able to form around curved edges? And as for the car wash question I dont know I bought the car a few years back so its life before I bought it is unkown but now that I think about it I guess a lot of car was trips could wear the paint down. I have always hand washed all my rigs thats how you really get to know them haha. I know shes an older impreza but im hoping I can give her a bit of a touch up to keep her lookin a bit better, plus its a 2.2 that just hit 140k So I should have many more miles to go. I just installed a new oem clutch kit and will be doing the timing belt soon. Last owner did the belt but none of the pullies or the water pump so guess ill be re-doing it.
Forrester Custom Sub Enclosure and Audio System
NWSubie replied to bobwires's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat looks really good! I have been wanting to learn how to do fiberglass work for a while now would be nice to be able to do custom stuff like that.
