3
opus last won the day on June 1 2021
opus had the most liked content!
About opus
- Birthday 06/27/1961
Contact Methods
Website URL
http://www.accountedfor.net
Gender
Not Telling
Location
Trout Creek
Occupation
I do it all
Vehicles
87 Brat, 86 GL, 86 GL10-Turbo
Recent Profile Visitors
opus's Achievements
Certified Subaru Nut (8/11)
49
I always adjust them when I have the heads off. Tell me about doing it with the belt on. Manual says LH side crank arrow up is TDC, do #1, then rotate 180, do #3, rotate 180 do #2, rotate 180 do #4. However, i see people doing it TDC then 90º, then another 90, etc. I'm assuming it can be done either way?
'02 Outback heads
opus replied to opus's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
I found heads. Everything for me has to be online. Any machine shop, parts yard, etc is 150+ miles away. -
'02 Outback heads
I'm having no luck finding heads without getting borked. Where's a good place for valves, seats, guides? -
'02 Outback heads
No oil consumption or leaks. 200k 2nd owner, very well maintained. It goes away 90% but pretty quiet warmed up.. -
Using a Stant thermostat. A thermostat is a thermostat. Either it works or it doesnt. I have put 2 of them in boiling water and the both open evenly. 2 days ago, the thermostat was fine. I've done at least a handful of these with no issues. When it was good and hot, I popped the thermostat out....the one that I have been using with no issues......it was still closed. I honestly think its steam pockets thats causing it. Lower hose is cool but trust me, there are no air pockets. I pulled every line off the top of the engine and bled it that way. Water pump has good circulation with the thermostat out.
New water pump. I flushed the block both ways and there are no blockages, nor clogged lines. This is my car. Its not the headgaskets. I ran it 20 miles with no thermostat. Its a new long block I built 9k miles ago. I've been driving it daily with no issues. You dont just drain coolant one day and have it all fall apart the next day. There was nothing wrong with the car before I drained the coolant. What I am thinking is that pure water is boiling fast, creating steam pockets and not letting the thermostat open. Now that I have slept on it some.
