19
Everything posted by Crazyeights
Very nice!
Hi from SE Washington
Crazyeights replied to PalouseLeone's topic in Meet n' Greet. Your USMB Welcome Center
Welcome, USMB is a great place. -
Is it possible to swap the transfer case on a MT?
Crazyeights replied to pgerbz's topic in Old Gen.: 80's GL/DL/XT/Loyales...
You're right it is.- 7 replies
- transmission
- dual range
(and 3 more)
Tagged with:
I installed an XT6 5MT (3.9 ratio) ring and pinion into a full time 5MT (3.7 ratio) dual range and it works. I think that your ring and pinion swap should fit. It's a fair amount of work though.- 7 replies
- transmission
- dual range
(and 3 more)
Tagged with:
Show us your radio console EA81 units
Crazyeights replied to jono's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Here is the slanted style console in my 1983 EA81 Wagon. -
By a nice Snap On ratchet and you will have it for a long time. They are expensive but worth it IMO. I think that they make a style just like that Champion one too.
1981 Hatch DL 4WD EJ22 Swap
Crazyeights replied to Andymccauley's topic in Old Gen.: 80's GL/DL/XT/Loyales...
What are you going to use to modify the holes? -
Yes
Looking good! -
I would suggest flow testing the radiator to make sure that it isn't plugged up. Simply hook up a garden hose to one outlet and watch the other one flow, or not.
Silicone axle boot on brand new axle
Crazyeights replied to Nickoli's topic in Old Gen.: 80's GL/DL/XT/Loyales...
My question would be why are you having so many CV boot failures. I have 4 modified EA series cars one of which has a 4" SJR Lift with 15" wheels. The last time I changed a CV boot or axle on any of them was years ago. Are your motor mounts and pitch-stopper good? Is your car lifted? -
XT AWD 5 man in EA81 - done it?
I am trying to understand what you are asking so I can help. So, the trans no longer shifts since you opened it up to swap the stubs? -
Loyale door lock switch fix hack.
Crazyeights replied to cnc's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Thank you for this. Some of the older power window switches are fixable like that too. -
Rear disc questions
Crazyeights replied to XHighOctanex's topic in Old Gen.: 80's GL/DL/XT/Loyales...
You'll need 2 complete rear calipers with brackets and bolts, pads, rotors (with rear hubs), backing plates, and I would grab the rear brake hoses as well. You don't need to touch the bearings. -
GL RIP or Shell Resurrection
Crazyeights replied to Animated Meat's topic in Old Gen.: 80's GL/DL/XT/Loyales...
If you get stuck I still have some pictures of my EJ swap shift linkage that might help.
Need a SPF I wiring harness diagram please anybody
Crazyeights replied to pbilt's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The SPFI conversion file is here in my Dropbox; https://www.dropbox.com/s/k4kdbpaclc6sko4/EA81_SPI_guide.pdf?dl=0 Until it isn't -
I my opinion it's a good idea to give the rest of the exhaust system a quick look while your at it. If the pipe/muffler hangers are missing or in bad shape this helps to rip the studs out of the heads, even if you just repaired them.
This thread was lots of fun to read through Thank you for taking the time to share it! The pictures are awesome too
