19
Everything posted by Crazyeights
ea82 cam tower oil seal question.
Crazyeights replied to darsdoug's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Is their any possibility that the fuel pressure and return lines got swapped by accident during the surgery? -
It sounds like I am being way too fussy. It looks like the general consensus is to just run them unless they have been creamed by a piston or show obvious signs of being burnt. That's exactly what I wanted to know. Thank you for all of your opinions As far as the customers cars I work on the machine shop makes the call, so this info is just for my own projects.
I was wondering what others do to bench test valves for leakage when checking used heads or when they are off for gasket replacement etc? I know that you can spray brake cleaner down the intake and exhaust valve ports and look at the faces for leaks. Some folks pour water in the combustion chambers and use a blow gun to push air in to the ports against the back side of the valves and look for bubbles, is this a better way? It seems like almost every valve I check with brake cleaner seeps a little bit, yet they were running fine? Is lapping in this situation recommended or will that just accelerate wear and make it worse?
EA81T fuel pump / fuel damper problem
Crazyeights replied to Subar.Dude's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I probably have a "can full" of those things here. I'll be happy to mail a couple to you (for postage) if you get stuck. The catch is I am busy and slow sometimes -
It looks like it might just be a pulse damper. If so, EA82 SPFI cars are loaded with those things. I would try using an EA82 one and see what happens. -
The vacuum lines can be plugged. I'll have to look up what I did to make all the lights, NSS, etc working.
You should be good to go. The ratios should both be 3.9. I have done several D/R swaps recently and they fit/work great. Some details need to be sorted out with the trans wiring harnesses but they're minor.
Anyone ever use teflon wrist pin buttons
Crazyeights replied to superooo's topic in Old Gen.: 80's GL/DL/XT/Loyales...
In my opinion this would not benefit the EA series engines. There are plenty of things you can do that don't cost much extra. If you have extra time on your hands you can take detailed measurements of everything that you re-assemble, bearing clearances, piston to cylinder wall clearance, piston ring end gaps, connecting rod weight for balance, etc. Being as anal as humanly possible try to get everything as close to the "tight end" of the factory specifications as you are able. The engine will make more power, run quieter and be more efficient. You will be more proud of it too -
One option is to read through the steps in a repair manual and see if you are up to it. The factory service manual is available from a number of sources.
Trying to save a special Brat in Elsinore, CA
Crazyeights replied to RAD's topic in Meet n' Greet. Your USMB Welcome Center
Good luck at your new job Hopefully your situation will start to improve soon. -
The supercharger on the Mad Max car was for looks only. It didn't actually work.
Loyale cargo mat/carpet?
Crazyeights replied to RubberMonkey's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I have a rubber mat out of a Legacy in the back of my Loyale. -
I ordered a set and they look good.
https://www.millsupply.com/auto-body-rust-repair-panels/subaru/
You will need the engine crossmember from the EA82T car too. The exhaust up-pipe to the turbo won't fit without it.
Quick lsd question, just a lil diff
Yes you do -
EA82 filter bypass permanent fix
Crazyeights replied to Treblemaker's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I have had to contend with this too. I'm interested. -
XT6 rear hubs EOI in 5x100 & 5x114.3 ?
Crazyeights replied to dfoyl's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I would like to be on the waiting list for a pair of these if possible. They look great -
EJ conversion into my '92 Loyale
Crazyeights replied to LittleLoyaleMan's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The wheel arch trim was already there when I bought it. -
Here is my '92 Loyale with the EJ22 and EJ 5MT conversion done. It also has the 5 lug swap done with 16's in this picture. -
I have an EJ swapped '92 Loyale. I have done the EA - EJ conversion several times now. There are many positive reasons to do this swap. There are also some things to take into consideration. The conversion will most likely take longer and cost more that you expect. There are always delays and extra costs no matter how well you try to plan ahead. Next, the old EA82 Loyale that you have gotten used to will be gone. Your car will have a totally different feel to it, like a different 'personality' almost. The power to weight ratio will be awesome compared to ridiculous! I have an 88 DL with an EA82 in it too. The difference between the two cars is night and day. Good luck and please post pictures if you go for it
