19
Everything posted by Crazyeights
I would like to put a condenser for the AC there (spare tire well) as the EA81/EJ22 swap has left no room up front for anything but the electric fan.
EJ swap issue...Exedy XT6 clutches discontinued?
Crazyeights replied to El Presidente's topic in Subaru Retrofitting
I went with a Sachs XT6 clutch kit that I ordered locally for my EJ22 swap. Not enough miles on it yet to comment on longevity, but it feels/works great so far. GD has said just to buy the XT6 pressure plate from the dealer. I have no idea if they can still get them - pretty spendy option last time I priced it. -
It is about half as thick but the heat transfer and life expectancy of aluminum is supposed to be better than copper/brass. I think it will be worth the extra trouble to fit it. Both of my used original units look so bad I'm not sure they could be saved. Might also consider doing the heater control valve while you are in there, but it adds another $100.00 to the bill.
The 9340 heater core will probably be aluminum instead of brass and it's going to be a tight fit in the case. It will take some trial and error with the foam to get it right but it will go. You might also have to trim a little off of one of the heater control valve tubes:(
Let me know if you find a factory one at a good price. My ej swap has blown out about 5 used EA81 oil senders! I finally just gave up on the oil pressure gauge:(
You can't change the cam timing on an EA81 without splitting the case, at least not that I know of. If all you are doing is putting the heads back on then nothing to worry about. I would either back off the valve adjustment or move the pistons down in the bore when snugging down the rocker assemblies on each side just to be safe.
EJ22 swap and custom FT R/X trans with 3.9 gears from an XT6 (205/70R15 tires) 18-20 in city driving and about 28 Freeway if I keep my foot out of it:D
ea82 flywheel question
Crazyeights replied to subarurx yo's topic in Old Gen.: 80's GL/DL/XT/Loyales...
FWIW SJR did the XT6 flywheel I used in my EJ conversion and did a beautiful job! One local shop wouldn't even touch it. -
Until recently I was running the same setup. Mine was a freshly rebuilt EA81 with SPFI. I tried both the original SPFI routing of the PCV and the dealer modified version with the new blue "tee". I always had oil in the intake around the IAC and in rubber intake bellows. It bothered me, however I spent so much time chasing valve train issues and low end drivability issues I never did get around to solving it. Good Luck
The garage queen gets a new heart ::ea81 build::
Crazyeights replied to Idasho's topic in Old Gen.: 80's GL/DL/XT/Loyales...
It will, and you still maintain all of the good low end driveability traits that seem to go away with the torque grind. -
Beautiful work! I also know how much extra work it is to stop, wash your hands at every step, and take such nice pictures. Just curious as I am doing 1 last EA81 myself. What if anything was done to the cam and lifters? Are they put back just like they were, reground, or? I had bad luck with the torque grind on my last hi-performance build and I am thinking of just putting the stock used ones back in. -
Probably my last EA Rebuild - an EA81T
Crazyeights replied to Crazyeights's topic in Old Gen.: 80's GL/DL/XT/Loyales...
PM Sent -
Did they sell me two left head gaskets?
Crazyeights replied to thedoctor's topic in Old Gen.: 80's GL/DL/XT/Loyales...
They should both be the same part number as I recall. Just flip one over. -
I am slowly collecting parts to finish this up. Would this be an ok deal on the correct water cooled turbo? Almost all of the ones I have seen at the local pick-n-pull look like junk. Ebay XT IHI Turbo -
Some real life experience with the EA81 I built - FWIW:) Ea81 with EA71 pistons, ported heads (shaved .020), Delta torque cam, SPFI conversion running about 35PSI fuel pressure. Timing makes a really big difference with this engine. It will run fine at 20 degrees but the sweet spot seems to be about 28 degrees. I had to mod the distributor mounting plate to do this. Can't push it any higher than that though.
@wilcox One of the front plugs is covered by the water pump rather than the oil pump;) -
You pull out the pins, install the rings on the pistons (after checking the end gaps) and using a ring compressor install the piston with the connecting rod at the bottom of it's travel. Carefully line up the eye in the small end of the rod with the pin hole in the piston and insert the pin through the access hole. Note don't forget to install the inside pin clip before you put the piston in or you can't get to it. Put the outer clip in through the access hole. Repeat 3 more times and your done. -
Watching this one:popcorn:
