19
Everything posted by Crazyeights
This was the best I could get with my cell phone
I just pulled an EA81 down last week. The distributor drive gear is on the front end of the crank. Remove the pulley and the seal and it should slide right out. I think the gear is a soft metal like aluminum so it could be worn. The beveled side goes in towards the engine. Good Luck!
Help on a few things
Crazyeights replied to 92_rugby_subie's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Try Naval Jelly on the rusty chrome wheels. -
Thanks Bennie that's good to know. I am still trying to decide on weather or not to go ahead with the EA81T build or just shelve it for now and finish my EJ22 conversion. So far I have a good block that would end up .020 over with new pistons and (2) good pair of heads already pressure tested - ready for valve grind, seals, and surfacing. The EA81 Turbo engine cross member all cleaned up
Broken intake manifold bolts EA 82
Crazyeights replied to bigjimd's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The shock of an impact does seem to have a positive effect on breaking up the corrosion. -
Someone here told me to use 3/8 impact on those and they almost never break that way. So far after the usual soaking with PB ect, this hasn't failed me yet. I know it sounds crazy but it works:eek: -
Things to look for on 2g Brat?
Crazyeights replied to jimbob_racing's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The BIG one on older Subarus is rust and hidden rust. Missing parts even rare ones can be found or made if you wait long enough and are prepared with a big enough budget. If you get something with so much rust in the cowl area that water pours on on the floor during every rain spell you will not be happy. This isn't easy to repair unless you really know what you are doing. Look CAREFULLY at the area around the door hinges and at the rocker panels. Give a light pull on the wire grommet where is passes through from the door to the body. Does it feel like it's going to pull the surrounding metal out with it? A little surface rust here on a car that has been painted over can hide TONS of damage. Also make sure the suspension is safe and solid where it mounts to the body as there really isn't any frame. On a Brat look at the wheel well areas in the bed and see if the shock mounts are rotting away at the top. Is the drivers seat about to fall through the floor when you sit in it? Look closely at the floor pan behind the seats, if it's even there is it all beat up, does it have a pool of water sitting in the low spots? BTW look closely at the spare tire area under the hood, leaks here will poor right in on your feet. Pull the T-Tops if it has any and look for roof rot all around the area of the hinges and latches. Look for rot at the windshield pillers, ect. Again, crawl under it and look one more time for structural damage as mentioned above. Good Luck and have fun! -
Lots of your questions are answered in a recent thread. Thread about buying older Subarus -
Anyone on the megasquirt?
Crazyeights replied to nncoolg's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Does this help? Megasquirt your RX Turbo -
Tool for removing connecting rod pins?
Crazyeights replied to afewsubarus's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Great! Thank you. I wish I had known about this 2 days ago:grin: -
That's a great idea, I wonder if it would work? I just did this again on another EA81 with a ground down battery J-Hook bolt. It sure would be easier with the right tool. I think it's a Lisle 13750. -
I'm not sure it's possible without lots of creative fabrication. I've done quite a bit of searching on the same subject recently. Some REALLY talented people here have done some nice factory looking swaps and decided that there just isn't room for an AC condenser, cooling fans, and a radiator.
Update, I have the case disassembled, split, and everything pressure washed. Out of all the EA81 blocks I have torn down so far this is the best with the features I want. Hydraulic lifters, all the accessory mounting holes on top for PS/AC Turbo or not depending on which pistons I choose, multi-port heads, ect. It looks like it would need to be bored oversize. So I need to decide if I am going forward with this build which pistons to use.
Great! Can't wait to see them. I am about to go through this on mine. Did they use any urethane or anything on the gasket or install it dry?
I have done some searching. From what I have read in other threads it looks like there isn't room for air conditioning and radiator cooling fans when swapping an EJ22 in to an 83-84 EA81 body correct? So the engine options if AC were desired would be limited to EA81 or EA81T? If it comes down to it, I wonder if an EJ22 swap without AC is worth moving away from an EA81T that has factory AC? Thoughts? Just thinking through some details for one of the worlds longest ongoing Subaru projects:grin: Thanks in advance [EDIT] I stripped down an EA81 Hydro core yesterday and it had a big 2" crack right through the water jacket where it apparently sat without antifreeze in it:( This was my last Hydro EA81T core. I opened it up today and it looks like it has had coolant sitting in one of the cylinders for a bit too long. I doubt this will hone out. I have pulled about half a dozen of these EA81's down now and all but one are basically junk. Looks like it may be finally time to give up on the old EA blocks as much fun as they are and finish my EJ22 Swap - AC or not:rolleyes:
Did you do the windshield? I would really like some details if possible. Any rust in the channel or cowl area you had to deal with when the windshield was out? New gasket or re-used? Thanks, Great Project!
