Nate E.
About Nate E.
- Birthday 12/22/1969
Location
PDX
Vehicles
'83 GL almost to the moon
Nate E.'s Achievements
Member (2/11)
2
13 inch tire discussion
Nate E. replied to Mechanical_misfit's topic in Old Gen.: 80's GL/DL/XT/Loyales...
'83 GL 2wd wagon here. 185/70-13's all 'round for 3 season driving. A pair of WestLakes & a pair of Thunderer's from Les Schwab. Yeah, I know, not matching. It's a 2WD machine. These are basic, cheap tires that look nearly the same. They are noisy. That's really my only complaint. Wearing just fine. I've gotten 30+ mpg on highway travelin'. For winter tires, I just installed a set of non-studded Nokian Hakkapeliitta 7's. 175/70-13's. Found a deal at SimpleTire. https://simpletire.com/nokian-p175-70r13-t427757-tires?stmodel=hakkapeliitta-7&stcategory=winter&sttype=passenger&gclid=CMiU35z8788CFQMaaQodHjED7Q They are wonderfully quiet & roll way smoother. A supple feeling tire. The rain performance is fookin' awesome. No pulling or floaty business. They feel just a wee bit squirmier in the corners than the other tires on tarmac. RPM's are up just a tick for a given speed. 2800rpm is a GPS 62-63mph. A few miles on some greasy 32deg cold damp road a couple weeks ago. Seemed stable. Predictable. Haven"t put any snow miles in yet. Looks like I'll get a chance in the next couple days. NE -
I've got a hydrolifter EA81 longblock that was not showing any compression on #1 cylinder. Leak-down test showed huge leak past the intake valve. Popped valve cover off to check that it's not stuck valves. No stuck valves, but signs of monkeywrenching on #1 tappet adjusters. Hmmmm. Pop head off; the valves had kissed the piston tops. Damn. Most noticeably on #1 Intake. Less on #1 Exhaust. #3 piston top shows a kiss, as well. Double damn. Removed #1 Intake valve and roll the stem on a piece of glass. Yep. Bent. There's a ding in the valve stem. ??? More monkey action. Headgaskets were Felpro's, so the heads have been off before. Maybe the cases were split and the cam didn't get timed correctly. Nope, got a centerpunch mark visible through the chamfered flywheel bolt hole when it's at 12 o'clock. Hmmm. Is it possible that upon re-assembly, said monkey with wrench fiddled with the DON'T ADJUST tappets, turned the motor over and bent the valves? Can that happen if the adjusters are screwed in all the way and left there? I know that's the second step in adjusting the DON'T ADJUST tappets. First step is put the piston somewhere in the compression stroke towards TDC, if not TDC. Then the screws are backed out to zero lash plus another turn or so. Nate
PM'ed you about the engines. Very interested in one. Maybe I can roll out to check them out this weekend. Thanks, Nate 503.481.7345
Awright, you're talking my language. Gives me incentive to get that rack swapped. Not sure of a timeline on my part yet. You officially have first dibs on my PS system. Nate
@TurboSubsruBrat Well, I've already got the rack. Not sure when I'm gonna do the swap. Have in mind to do struts/ball joints/steering rack in one fell swoop, followed by an alignment. I'm looking for EA81 engine stuff, so I'll keep you in mind for the PS system. Got anything? You in Portland area? NE
The PS system works just fine. Just working on simplifying the car and more go juice for the wheels. It's such a small car that I feel no power is needed for steering. I'll eyeball the existing PS crossmember more and give some feedback here. Nate
I have an '83 GL FWD w/ power steering & want to swap in a manual system. I have the manual rack. I've dug around the interwebs & it looks like I might need the manual crossmember. Is that due to mounting differences and/ or different holes and reliefs for the P/S lines? Nate
Oh, duh. A look at an interwebs picture woulda told me that. And a Corvallis question for you, Mr. Gloyale; anybody in Corvallis into EA81's? I need a crank. Thanks, NE
Hey check these guys out: http://www.philbingroup.com/rebuilt/distributors.htm Maybe he's got parts n stuff. NE
I'm in need of another crank for an EA81 rebuild. I noticed on a couple engine rebuilder parts websites that the reground EA81 and EA82 cranks are the same part number. They use the same bearings, seals & rods. Is the flywheel bolt pattern the same? If so, this makes the part search just that much easier. Thanks, Nate
Well shucks. Thanks turbo. The reason I ask is that a few Ishino ones are left @ autopartswarehouse for $8.95ea. http://m.autopartswarehouse.com/details/Subaru/GL/Ishino/Cylinder_Head_Gasket/1983/Base/4_Cyl_1-dot-8L/W0133-1652685.html NE
Well, this is probably a dumb question, but are EA71 & EA81 head gaskets compatible? Same cylinder bore. I dug around USMB & the interwebs a bit & didn't find a conclusive answer. No access to parts pdf's right now. Presumably they have different Subaru part numbers. NE
