13
Mike104 last won the day on June 22 2021
Mike104 had the most liked content!
About Mike104
- Birthday 06/24/1956
Gender
Male
Location
N KY
Occupation
Field Service Rep
Referral
From Outback forum
Biography
Lives in Northern KY. 1999 OBW 2.5 DOHC 4EAT, 2003 Forester JDM EJ20 5MT, 2008 Impreza WRX 2.5L SOHC 5MT
Vehicles
99 OBW, 03 Forester, 08 Impreza WRX
Recent Profile Visitors
1525 profile views
Mike104's Achievements
1000+ Super USER! (9/11)
149
I know the EJ25 DOHC are prone to overheating when the head gaskets go due to exhaust leaking into the coolant. I thought the EJ25 SOHC are more likely to have external leaks that could possibly result in overheating if the coolant level runs low. I've seen a number of older Subaru's for sale with the SOHC that complain about overheating (would stay away from since one wouldn't know how badly the lower end is) but was just wondering.
I did this on my 2003 Forester and the only way I could get it off was to cut the long bolt and burn out the rubber bushings in the knuckle. Since I needed it for a daily driver I splurged and bought two new knuckles, long bolt, two rubber bushings as well as a new bearing, hub and seals. Once I got the old stuff out it was a matter of just putting everything back together. I used the Harbor Freight wheel bearing installation tool to put the new bearings in. May not work for you but it's how I did it after watching many videos and expected a PITA time. Even using all new parts it was still a pain.
Interval is 105,000 miles or 7 years and have used Aisin kits and had good luck on multiple cars. Just don't buy stuff from Amazon or eBay as they can be counterfeits. Rock Auto has good on Aisin kits (Japanese parts). Retail prices for parts at a Subaru dealer can be expensive. Some online dealers give a good discount. Go here to look up part numbers: https://www.subaruparts.com/?p.SUB759&keyword=subaru parts online&gclid=EAIaIQobChMIt_ra7rzn7gIVccqUCR3zeAJgEAAYASAAEgKKs_D_BwE
My oldest child (totally useless with technical things) was going to relocate to Portland and I was hopeful that they would at least be able to get car work done at your shop. Alas it's now Seattle. As I will be across the country I will no longer be in a position to help when car issues arise. Hopefully AAA will be able to get the car to you
If the OEM parts from Subaru are too expensive for your budget, the Aisin Kit is probably the best option. Buying parts from ebay/Amazon can be risky as some sell counterfeit parts and it can be difficult to determine which ones are real. The Gates kits have been known to put Chinese made parts in them. Aisin is the OEM water pump manufacturer for Subaru. I believe Koyo makes the idlers and NTN makes the Tensioner. Mitsuboshi supplies the timing belts. The preceding statement is what I have heard so it may not be 100% accurate.
