13
Everything posted by Mike104
In theory weak brake hoses could cause an issue but those tend to harden with age not get softer so not sure if that is anything to worry about. If they are original calipers the pistons may be seized or binding that would cause your issue but should show up with pads that have little wear. May want to bite the bullet and get new calipers if you can't break the pistons free
Definitely more to torquing head bolts than the torque value. FSM probably easier to find for most Internet users than a machinist handbook. Some experienced people can accurately use that source but FSM has the torquing procedure as well as the values in one place. I work in the aviation industry where the most accepted source is the Aircraft Maintenance Manual. The FAA frowns upon using any sources other than that. I do enjoy working on my car much better than airplanes, way less paperwork involved.
ABS does not really have much impact if not working it really only prevents wheel lock up. Bleeding, bad master cylinder and proper brake pad bedding are the best solutions to brakes. I find my older Subaru's to need more pressure compared to the 2017 Impreza rental I had the other day. Just about put my manager through the windshield when I stepped on the brake pedal as hard as I do on my car.
