13
Everything posted by Mike104
I actually ended up buying new knuckles, bearing, brake backing plate, Lateral Link Bolt, Nut, washers and lower lateral link bushings from Subaru Dealer, seals and hub from Rock Auto and assembled the new parts and installed that. The removed knuckles were damaged when cutting the lateral link bolt out with a cutting wheel. I would not want to try and take a rear one out from a pull and pay yard.
Check www.car-part.com for interchanges. Depends on FWD, AWD with or without ABS. Difficulty is getting the lateral link bolt out. I just did two rears on my '03 Forester and ended up having to cut the lateral link bolt and burn out the lower bushings. Probably want to have a new lateral link bolt, nut and washers on hand as well as two new lower lateral link bushings.
Best option for head gaskets is an electronic CO sniffer. They are expensive but most shops have access to one. Other option is a chemical CO tester but it is not as accurate. The SOHC H4 engines tended to have external oil/coolant leaks rather than exhaust gas leaks into the cooling system like the DOHC 2.5L engines
AT fluid is a different animal. According to the owners manual for your MY, oil meeting API classification SM with Energy Conserving or SN with Resource Conserving are acceptable oils. ILSAC GF-4 or GF-5 are also acceptable. Mobil 1 meets these specifications. Feel free to use what you wish. Pages from MSA5M1404ASTIS_18.pdf
The caliper bracket bolts are 17MM Strut bolts are 19mm. The rotor is not attached to the hub except for being sandwiched between the wheel and hub. You may need two M8 x 1.25 bolts to extract the rotor from the hub. The axle nut is 32MM or maybe 31MM. You can generally rent a set of axle nut sockets from most auto parts stores. If you are going to change the bearing you will need either a hydraulic press (20T preferred) or a set of FWD bearing tools. Some shops will replace the bearing for you if you bring the knuckle and parts in with you. Here are a couple of videos to give you and idea of what is involved: http://<div style="position:relative;height:0;padding-bottom:56.21%"><iframe src="https://www.youtube.com/embed/d1no7NDMbwE?ecver=2" style="position:absolute;width:100%;height:100%;left:0" width="641" height="360" frameborder="0" allowfullscreen></iframe></div> http://<div style="position:relative;height:0;padding-bottom:56.21%"><iframe src="https://www.youtube.com/embed/2kUUEryHHAw?ecver=2" style="position:absolute;width:100%;height:100%;left:0" width="641" height="360" frameborder="0" allowfullscreen></iframe></div> This post uses the hydraulic press method https://forums.nasioc.com/forums/showthread.php?t=787070 I've done a bunch of these using the HF FWD kit and the hydraulic press method.
Here is a long article about "oil consumption" and a list of worse offenders: https://www.consumerreports.org/cro/magazine/2015/06/excessive-oil-consumption/index.htm As explained better elsewhere by GD the oil consumption was a design trade off to improve gas mileage. Less ring friction for better mileage, less efficient oil scraping, leads to consuming oil between oil changes. The fix for Subaru was to put in a new short block that got up to 3 MPG LESS. A quart of oil between oil changes is a cheaper option than reduced fuel economy IMO.
Here are the affected vehicles for the extended warranty Covered Vehicles https://www.girardgibbs.com/subaru-oil-consumption-class-action-lawsuit/ The “Settlement Class Vehicles” are: Automatic / CVT Transmission: 2011-14 Forester (below VIN *529004) 2012-13 Impreza 4-Door (below VIN *033336) 2012-13 Impreza 5-Door Wagon (below VIN *886714) 2013 Crosstrek (below VIN *856139) 2013 Legacy (below VIN *048086) 2013 Outback (below VIN *321435) Manual Transmission: 2011-15 Forester (below VIN *543650 ) 2012-15 Impreza (below VIN *270253) 2013-15 Crosstrek (below VIN *270284) 2013-14 Legacy (all) 2013-14 Outback (all)
Looks like it's attached from the back side with screws. My thought would be that you would need to remove the door panel to get access
- 5 replies
- switch cluster
- door panel
(and 2 more)
Tagged with:
You could try these guys: https://www.mttechsuba.com/used-subaru-parts/ Not cheap but good parts. Stored indoors instead of lying around in a field getting wet and rusty. I bought one before I learned how to change the bearings myself and it was perfect. Other option is to get a used one from a yard and replace the bearing. Also try car-part.com for used parts near you.
